THCAD charge from mode 1 to mode0?
3 years 6 months ago #268064 by Ekholm
Hi! I have diagnosed that my reed relay fort the arc ok is not working. I don’t get a signal when firing my plasma. So i’m thinking about changing from mode 1 to 0. Can I do that without running the wizard? What do I need to change? And what is then suitable max and min voltages? I’m going to contact my Chinese supplier for the plasma for a new relay, but this is a quicker way for me to be up and running.
3 years 6 months ago #268065 by Clive S
A picture of how you have the reed switch configured would help.
Ie. have you wrapped the cable around it about three turns.
3 years 6 months ago #268068 by tommylight
Also, reed will not trigger when firing the torch, only when cutting.
Use some scrap to check while the DVM is in buzzer mode and both leads wired to both reed terminals.
3 years 6 months ago #268072 by tommylight
No double posting, the other topic deleted as it was copy/paste of this with the same tittle.
3 years 6 months ago - 3 years 6 months ago #268073 by Ekholm
Sorry for double posting. Thought that I failed to post the first time. The plasma cutter is a Herocut 55X with a cnc port. I have tried measure with a multimeter and I get no contiunity when the arc is established. I can see on the 7i96 that it ain’t receiving the signal. So I think the relay is bad
i feed a 24v signal (direct from power supply) to reed relay/ arc ok port and has it connected to input of 7i96
Last edit: 3 years 6 months ago by Ekholm.
3 years 6 months ago #268087 by tommylight
Clive asked for pictures, get us some pictures.
Find or borrow or buy a very cheap DMM (digital multi meter) cost from 5$ and up, use it to check stuff.
Insisting on "Mesa shows no signal" implies you have already tested and verified everything up to it, and then set everything up properly in hal and ini.
That is way to many things that can mess the results, from miss wiring (Mesa input 1 is NOT pin 1 on headers) to a simple editing error.
Check from source, in this case from reed contacts with a DMM and follow the signal path....
Time to create page: 0.056 seconds
