THCAD charge from mode 1 to mode0?
3 years 6 months ago - 3 years 6 months ago #268097 by Ekholm
The relay is indeed working! I opened up the machine and checked if I got a signal when activating with a magnet and it worked. I then went back to the cnc plasma and tested it and checked all the cables and everything is OK with the wires. I run some shapes in LinuxCNC but I will not get any signal when I waits for arc ok (not on 7i96 card and not I LinuxCNC). If I then ignore Arc ok then I will get a signal( both on 7i96 card and in plasmac (shows arc ok). I can’t figure out what’s different. Can my pierce height be to high? Can I have a delay some and when the plasma fire and burn away the material the contact is broken ? I really can’t understand why it behaves differently when I ignore arc ok.
Last edit: 3 years 6 months ago by Ekholm.
3 years 6 months ago #268171 by Ekholm
So my thoughts is that i will use the thcad card instead for meassure arc ok.
3 years 6 months ago #268189 by Ekholm
I found the problem. It was the pierce height. When I lowered it it now work (approx 2.5 mm height now)
Time to create page: 0.062 seconds
