So i tried to re-configure with no luck so i started at create new and went through all the steps again and i entered in terminal what you mentioned previously and finally a page popped up with some errors. I managed to get through some of them however its saying i have an error in the torch on pin. I am using an everlast plasma cutter for now and went with mode 1 in plasmac configuration (not sure if this is the mode i should use). I'm just a little confused with the torch on and arc ok as far as wiring is concerned. I know i need to connect to field output pin so would this be the arc ok 24+ field power to TB6 field output for torch on? and arc ok 24- field power to TB6 field input for arc ok? On the everlast it would be 9 and 10 pinout. Thanks in advance
