Startup Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS ...
3 years 1 month ago #281015 by radicus
I can run axis gui on this machine.
Trying to configure a Plasma machine but I can't boot up
Running Debian 10
File Name: debugh.txt
File Size:5.04 KB
3 years 1 month ago #281018 by tommylight
3 years 1 month ago #281117 by radicus
Understood, do these files have the info?
File Name: linuxcnc_print.txt
File Size:767 B
File Name: linuxcnc_debug.txt
File Size:57 B
3 years 1 month ago - 3 years 1 month ago #281119 by radicus
File Name: linux_report.txt
File Size:9.2 KB
Last edit: 3 years 1 month ago by radicus.
3 years 1 month ago #281122 by tommylight
Did you install the required dependencies?
Should probably change to Debian 12 BookWorm as there will probably be dependency issues and Python versions.
Sorry for the limited reply, but no more info there except the segmentation fault.
3 years 1 month ago #281126 by radicus
I ran the script in the qtplasmac guide. But no luck I guess.. I will go the Debian 12 route. Thanks
Time to create page: 0.259 seconds
