QTPlasmaC can't find Python3-serial
2 years 11 months ago #284486 by tommylight
Hope all is well (or as well as it can be) in your part of the world!
My family, friends, neighbors are all good, so yes it is, some occasional s#it at the north side, luckily last time they f@ked up badly as they were planning a full on invasion on that side, we lost 1 but the world found out they are the problem. Was not enough they started 4 f@kin wars here to figure that out.
End rant.
2 years 11 months ago #284492 by snowgoer540
I'm glad to hear that!
I sure hope the world figures itself out soon!!
2 years 11 months ago #284514 by donell
snowgoer540,
This is a package install.
None of those terminal commands produced any errors.
2 years 11 months ago #284515 by donell
tommylight,
Thanks for the suggestion.
Tried what you suggested. It would appear that brltty is not installed on my machine.
It is worth noting that the pmx485-test works fine so it would appear that the serial interface is operating properly.
Don
2 years 11 months ago #284542 by snowgoer540
I found the error that is causing the failure within the try/except.  Because of the line it breaks on, I am guessing that your Port name is incorrect.
I pushed a fix for the aforementioned error.  It will likely reveal that whatever you put for the port is not found.  Unsure what you put, but it may be an issue with a leading or trailing /  , etc.
After the buildbot does its thing you can update to grab the changes.  For 2.10, the version will be v1.237.302
2 years 11 months ago #284543 by donell
snowgoer540,
Genius!
The port name was indeed incorrect:
/dev/ttyusb0
instead of
/dev/ttyUSB0
It now works fine and talks to the Hypertherm OK.
Many thanks for your help and to the others that have replied to this topic.
Don
The following user(s) said Thank You: tommylight, snowgoer540
Time to create page: 0.346 seconds
