E-Stop
2 years 8 months ago #293906 by Plasmanfm
E-Stop was created by Plasmanfm
Hallo phillc54
Wenn man den Extern E-Stop zb an hm2_7i96s.0.inm.00.input-06 setzt..
geht es wie es soll was mir nur stört das wenn der externe E-Stop Resetet wird der E-Stop Button " Grün " ist kann man das ändern ?
Das es so ist wie beim mormalen Start E-Stop Button drücken und dann Power ein jetzt ist es so : externe E-Stop Resetet E-Stop Button ist gedrückt
Power Button kann direkt gedrückt werden !
 f you set the external E-Stop to hm2_7i96s.0.inm.00.input-06, for example.
Is it working as it should, the only thing that bothers me is that when the external E-Stop is reset, the E-Stop button is “green”, can you change that?
It's like the normal start, press the E-Stop button and then power on. Now it's like this: external E-Stop reset E-Stop button is f you set the external E-Stop to hm2_7i96s.0.inm.00.input-06, for example.
Is it working as it should, the only thing that bothers me is that when the external E-Stop is reset, the E-Stop button is f you set the external E-Stop to hm2_7i96s.0.inm.00.input-06, for example.
Is it working as it should, the only thing that bothers me is that when the external E-Stop is reset, the E-Stop button is pressed “green”, can you change that?
It's like the normal start, press the E-Stop button and then power on. Now it's like this: external E-Stop reset E-Stop button is pressed
Power button can be pressed directly!“green”, can you change that?
my thank´s
and king regarde
Juergen
2 years 8 months ago - 2 years 8 months ago #293953 by phillc54
Replied by phillc54 on topic E-Stop
What E-Stop mode do you have configured, it will be in your .prefs file as:
[GUI_OPTIONS] Estop type = 0
Could you also post a copy of your latest custom python code.
Last edit: 2 years 8 months ago by phillc54.
2 years 8 months ago - 2 years 8 months ago #293972 by Plasmanfm
Replied by Plasmanfm on topic E-Stop
Hallo phillc54
I set the E-Stop via the LinuxCNC Pncconf.Wizard
and in plasma-juergen.hal:
net estop-out => iocontrol.0.emc-enable-in
Attachments the qtplasmac_custom.py
my thank´s
and king regard
Juergen
Last edit: 2 years 8 months ago by Plasmanfm.
2 years 8 months ago #294290 by phillc54
Hallo phillc54
I need to know which e-stop mode it is.
2 years 8 months ago #294348 by Plasmanfm
Hallo phillc54
The button is set via the Linuxcnc Pncconf Wizard
King regarde
and thank’s
Juergen
2 years 8 months ago #294350 by phillc54
Yes but I need to know what type of estop button.
Warning: Spoiler!
Time to create page: 0.149 seconds
