Ohmic probe aborts immediately
16 May 2025 04:03 #328547 by alangibson
Ohmic probe aborts immediately was created by alangibson
Hello all. I've got an odd problem with ohmic probing that recently cropped up.
When I tap the Ohmic Probe button in QtPlasmaC, probing immediately aborts without moving the Z axis. Normally I would assume that the ohmic sensing circuit is always closed for some reason, but it's definitely not that.
halscope shows that the ohmic sense feedback pin is never activated. The ohmic enable pin is however correctly activated.
I've verified that the relay on my breakout board closes when ohmic probing is activated. If I connect the ohmic sense wire directly to the table, probing again immediately aborts and the ohmic sense pin is correctly activated. I've also verified that the relay that closes when the sense circuit is closed is not activated.
Z axis is homed. It correctly probes when using only the float switch.
So my question is: what can cause a situation where ohmic probing aborts no matter if the sense pin is active or not?
16 May 2025 10:04 #328574 by alangibson
Replied by alangibson on topic Ohmic probe aborts immediately
Unfortunately it happens 100% of every time.
It really feels like a bad setting somewhere, but AFAIK I haven't changed anything relevant since the last time I used it a few months ago. I've been cutting thick material for a while so I just was just using float switch probing.
What I can't get my head around is that there is no indication that the ohmic sense pin is ever on. This makes me think there is an unrelated setting keeping it from probing. I tried adjusting the probe height, but that didn't change anything.
Float switch probing continues to work fine.
16 May 2025 11:13 #328580 by grijalvap
Replied by grijalvap on topic Ohmic probe aborts immediately
I do have the same problem, I see the ohmic probe is activated then when probe start it "find the plate" and try to go back however torch is in the up limit, then you have a error, I set the threshold to 18V and worked in probing but fail again during real cuts, mine is a water table.
please let us know if find the solution.
  • Moderator
  • Moderator
16 May 2025 11:54 #328581 by tommylight
Replied by tommylight on topic Ohmic probe aborts immediately
Video of the screen and torch? So twice.
18 May 2025 04:02 - 18 May 2025 04:03 #328676 by alangibson
If your torch moves at all you have a different problem than me. I'd recommend opening a new thread and ask for help there.
Last edit: 18 May 2025 04:03 by alangibson.
  • Moderator
  • Moderator
18 May 2025 04:05 #328678 by tommylight
1. Alan is right, not the same problem/issue
2. Where are the videos ?
18 May 2025 04:06 #328679 by alangibson
> Sometimes stuff shifts mechanically
I verified that the PCB is working as expected. No welded contacts, etc.
> Is the PC you use to control the machine "frozen in time" (not connected to the internet or outside world)
It is connected to the internet, but there are no automatic updates happening. The software hasn't changed in at least 6 months. I also haven't touched the relevant HAL sections in as long.
18 May 2025 04:08 #328680 by alangibson
Coming soon. Our 4G cell service and broadband internet went down for nearly a day :|
18 May 2025 15:08 #328712 by alangibson
At long last, here it is:
18 May 2025 21:20 #328721 by snowgoer540
Replied by snowgoer540 on topic Ohmic probe aborts immediately
The OHMIC TEST button does not move the Z axis.  The intent is to see if there is a short between the torch tip and the ohmic lead (a ball of oxide can do this, or water from a water table).
User Manual Explanation of OHMIC TEST
If you do have a short, or you create a short to test it, you also need to hold the button to get the OHMIC light to light up in the GUI as there is sometimes a delay.  The click you are doing is far too fast.
The following user(s) said Thank You: alangibson
Time to create page: 0.364 seconds
