- Thank you received: 3
QtPlasmaC using w axis
1 year 4 months ago #329908
by akim14
QtPlasmaC using w axis was created by akim14
I need help. I tried converting the a-axis to w, making it leaner. However, I keep getting errors like dro_a and torch_a. Is there an easy way to add a w-axis as z2 ? I made it by editing the handler file and ui file to overcome these errors; however, I can get it to show the z2, i looked at the QtVCP library there is z2 there
1 year 4 months ago #330118
Replied by tommylight on topic QtPlasmaC using w axis
Moved to "PlasmaC" section.
Time to create page: 0.222 seconds
