Setting up a machine without a Z Axis
1 year 3 months ago #332397 by Willie
I'm converting over an old Koike Oxy Fuel table that has a Burny controller on it to run on Qtplasmac. Swapped out all the electronics. Can move the axes around how I want and it'll run whatever shape I program. However a few issues in running into, probably just me overlooking ini file settings.
1. The torch won't activate at all when the program is running. The torch only works when I manually hit the "Torch Pulse" button.
2. I have a manually controlled Z Axis, no need for that auto height stuff on Oxy Fuel cause the height not being right is more forgiving. But the problem I run into is when I go to run a program without homing, it follows the path it should, but when I do home it goes to cut the shape and then the Z Axis starts moving on the screen and it throws the error "bottom limit reached while probing down". I feel like there's some simple solution that might fix both of these problems that I'm just not seeing.
3. Also a third random question while I'm here, I know I can set various pierce times for different materials but it's there a way to force the machine into always manually piercing, like a M1. But in the parameters/in, I that itll pause and make me hit like cycle start or something to do the pierce. Cause while I can let it run auto, pierce times are more finicky with oxy fuel and it can vary day to day and plate to plate.
1 year 3 months ago #332433 by tommylight
Much easier to use another GUI.
PlasmaC and QtPlasmaC are made with that automation embedded into them as they are essential for plasma use.
1 year 3 months ago #332445 by snowgoer540
For 1, do you have a M3 $0 S1 command at the beginning of your cut?
For 2, this would probably work:
linuxcnc.org/docs/devel/html/plasma/qtpl...c.html#plasma:keep_z then you could just zero Z at the correct height and use a g0 or g1 z0 to send it back at the beginning of each cut.
For 3, why not just use M1? I think it’s still valid in QtPlasmaC. Use the move to Z0, then M1, then do your pierce and press cycle start? ¯\_(ツ)_/¯ I also have almost zero experience with CNC oxyfuel tables.
1 year 3 months ago #332446 by snowgoer540
10 months 3 weeks ago #339766 by vikingj
I have solved this. I had a similar issue. Trick is to upgrade to 2.10 by compiling your own version. I highly recommend using ChatGPT or Gemini to help with this process. This has a new feature for pipe cutting.
What you then do is to enable pipe-cut in the HAL-config OR enable it through Hal Show, this avoids the Z axis movement probe cycle prior to running the program. I can now run my XXY with a fixed Z and get the torch to run without needing to do the probe cycle.
I also created a button in the UI under settings to toggle the hal pin pipe cut to make this easier because the flag was reset each time i loaded a new program.
Time to create page: 0.324 seconds
