Can anyone please help me with testing my CAM software?
- JumpPadGames
- Topic Author
10 months 3 weeks ago #339800
by JumpPadGames
Can anyone please help me with testing my CAM software? was created by JumpPadGames
I just need someone to test my CAM web app for bugs, feedback, and feature requests. Willing to add post processors to the software if its not there. The app is at plasmadesk.com no sign up works when u visit.
- LesNewell
- Thank you received: 22
10 months 3 weeks ago #339839
by LesNewell
Replied by LesNewell on topic Can anyone please help me with testing my CAM software?
I had a quick play and noticed a few issues.
Overall it looks like it has potential for simple plasma jobs. Are you intending to charge for this?
- How do you change the cut settings to use metric?
- I notice outside corners are just a straight line, cutting across the tip of the corner. This should be an arc or the edges should be projected to form a sharp corner.
- You don't appear to be able to specify outside or inside offset. All contours get an outside offset. Say for instance you are cutting a washer. The drawing is two concentric circles. When you cut it, both the inner and outer circles have an outside offset, resulting in an incorrect hole diameter. The inner should have an inside offset.
- Your report a bug link takes you to a 404 page.
- snowgoer540
- Thank you received: 907
10 months 3 weeks ago #339840
by snowgoer540
It appears so:
www.plasmadesk.com/LE/pricing.html
Replied by snowgoer540 on topic Can anyone please help me with testing my CAM software?
It appears so:
- LesNewell
10 months 3 weeks ago #339904
by LesNewell
It sounds a reasonable price assuming they actually keep supporting and updating it. The lifetime license only lasts as long as the site stays up. It will be interesting to see how this develops.
Time to create page: 0.048 seconds
