THC not getting active even when "all seemingly needed" requirements are met
7 months 1 week ago #344645 by AntonioT
Hello All,
New to the forum and first of all would like to thank you for the valuable information you guys post, it has helped so much me moving ahead with my build. id appreciate your help with my issue where it cannot activate the thc even when all the settings (that i know of) have been properly adjusted. first my setup:
-LinuxCNC QTPlasmac table
-Rpi5 with image LinuxCNC 2.9.8 Raspberry Pi 4/5 OS based on Debian Trixie
-Mesa 7176s over ethernet
-THCAD2 + 3M resistor array enclosed near the plasma source, F+/F- routed to mesaboard encoder input A with shielded microphone cable grounded at control side, also used a more simple twisted pair for testing.
-Used Pnconf for setting thcad2 trimming and ratio
Tested for correct voltage measuring for example, hooked a power supply from 39 to 56 volts and Main screen voltage readings coincide very accurately to multimeter reading.
-Flaring 65 plasma source with no cnc interface. (HF piercing) voltage probing connected to torch (-) and clamp (+) leads.
-For testing im using a straight line of 100mm at full speed so thc is not affected by speed reduction  (tested from 400 to 1800 mm/min)
-THC is enabled
-Mode 0 is used so arc ok is derived from voltage readings
-setup plasmac.arc_lost_delay =.3 as was having some issues for getting it to start cutting due to initial spike/valley.
I took the follwing HALSCOPE trace where:
1)torch on triggers,
2)probe voltage goes to 260 for piercing, then falls, then recovers to around 94v
3)Arc OK signal goes to true
4)Pierce delay elapses
5)Movement starts
6)THC active never goes up and of course  no correction
as Far as I can see voltage is "stable" once cut starts and there is no variation that could lead to deactivation as the tresholds are LOW=39 HIGH 990 (for testing purposes), samples 10 and threshold voltage 10.
has anyone had this issue or any lead on what to look at?
7 months 1 week ago #344652 by tommylight
Screenshot of the settings page?
In the meantime, disable:
-auto volts
-void sense/void lock
-set the arcok high to 160V
-set the arcok low to 60V
-set VAD to 60-65%
-set the cut voltage to (in your case) 100V
-set the feed rate to 2000mm/m
-set the jog speed to roughly 2000mm/m
-press F9 to fire the torch
-press an arrow key to jog
-watch the LED's on screen for arcok/up/down
Material for testing, 2-3mm thick, current set to 40-60A
Make some test cuts, check the under side of the cuts for dross and how easy it is to remove it, adjust feed rate/ air pressure (only while air is ON) and cut voltage till you get nice clean cuts with little dross.
7 months 1 week ago #344688 by AntonioT
Hello Tommy thanks for your response, yesterday in follow up to your suggestion I set the parameters as I will show in the pictures below and I have some updates:For the first time THC stayed enabled during the cut, this happened around once every 5-8 tries, dint have the chance to validate it worked properly but that is some progress.*Something that i was not doing before is to set same speed in material table as well as in the G1 command of the G code idk yet if that has something to do with it, please see the next items.*Normal behaviour in my setup is that screen always went black for a second or two right after the pierce, it was so consistent that thought it was a feature of the GUI, yesterday noticed only a few runs where the screen did not go black, some of those matched the times where THC remained enabled. I checked and seems that the black screen is rather an issue caused potentially by EMI?*Changed plasma source settings to increase pilot arc and I could see the screen going black more violently. i.e. with flickering before going black.I am making some improvements to grounding to see if this helps, do you have any recommendations to make the arc ok, feature more resilient? in case that it is emi or do you have any other idea thanks.
7 months 1 week ago #344701 by Plasmanfm
I have a Lorch plama cutter that ignites with hf....
By me was it the monitor cable ...
MfG
Juergen
7 months 1 week ago #344723 by AntonioT
i see, will look at it too. Was the HF start giving you issues with THC?
7 months 6 days ago - 7 months 6 days ago #344757 by Plasmanfm
Last edit: 7 months 6 days ago by Plasmanfm.
The following user(s) said Thank You: AntonioT
Time to create page: 0.214 seconds
