- Thank you received: 4
It's me or it's a bug?
- jazzkramer
- Topic Author
6 days 18 hours ago - 6 days 15 hours ago #350467
by jazzkramer
It's me or it's a bug? was created by jazzkramer
I searched but I did not find so I write this post.
Hi all!
I'm now using the plasma more: QtPlasmaC v 2.9-238.315.
I have some strange behaviours:
1) I'm cutting a shape that I moved to <0, 0> by the conversational (subtracting 0.6 from each axis).
When I start the cut, the 0,0 turn to 0.6, 0.6... I can't measure the real cut position but... finishing the cut it goes back to 0,0 as in this video:
(investigating more, luckily it seams it's a visualization error only)
youtube.com/shorts/QHeixNg3vI8?feature=share
2) I'm cutting one shape, than I'm pressing a custom GO TO X0Y0 button that moves the torch over the last start 0,0 position, than I'm moving the torch by 60mm pressing 6 times the X left arrow (10mm each time), then I pres X0Y0 button to set the new starting position.
Sometimes, randomly, when I click CYCLE START, the Z axis movement is ignored and the shape is "cutted" in the air. To correct this I need to press and switch off the Power button, than switch it on again. I think it's not an electrical problem of my machine because the shape cutting movement occur without waiting the Z movement time... I also move the Z with the arrows befor starting cut cycle... Here the video:
youtube.com/shorts/zjP_dUaLeVU
3) Moving the X axis by arrows, I got to the right limit switch. I remember from previous version, you press OVERRIDE LIMITS in the message and it works to go back inside the limits... now... it seams to be looping in the message and can't go back within the limit because message appears...
youtube.com/shorts/i5hVDSLVbTQ
4) AND, I just saw now: is it a flip, is it a mirror?
Original:
Mirrored:
Flipped:
Thanks, for any advice.
These are not blocking errors, I mean, I can live with that! It's just to inform you in case you don't know.
I apologize if they where already posted, I did not find them. And thanks to all developers!!
Alberto
Hi all!
Original:
Mirrored:
Flipped:
Alberto
Last edit: 6 days 15 hours ago by jazzkramer.
6 days 14 hours ago #350472
Replied by tommylight on topic It's me or it's a bug?
Moved to "PlasmaC" section.
- snowgoer540
- Thank you received: 907
6 days 4 hours ago #350478
by snowgoer540
Replied by snowgoer540 on topic It's me or it's a bug?
1) without your gcode it’s hard to tell what’s going on.
For the others, I would say that development for the qtplasmac in 2.9 stopped in August of 2024. Any and all bugs that have been brought up since have been addressed in 2.10.
It’s one of the unfortunate parts of the project that releases take years between versions. So much has changed in QtPlasmaC between version 2.9 and 2.10 that maintaining bug fixes in both locations for QtPlasmaC was not something I wished to spend my time doing.
Before he retired from the project, Phill rewrote a lot of the conversational code so I would imagine your issue has been solved in 2.10.
- jazzkramer
- Topic Author
6 days 2 hours ago #350480
by jazzkramer
Replied by jazzkramer on topic It's me or it's a bug?
Hi
thanks Tommylight for moving the thread to the correct forum section, I thought I posted it to the PlasmaC section but I mistook posting it to the general section image missing /media/kunena/emoticons/unsure.png
Thanks Snowgoer540, I will post/attach the gcode as soon as I get to the machine: I have the original gcode produced by SheetcamTNG and the modified gcode I saved by the QtPlasmaC I was actually using.
I think about one month ago' I installed the LinuxCNC last version downloaded from linuxcnc.org (Current release: 2.9.10) because the one I got was skipping some hole parts (I found a post about it)... I thought it included the last version of QtPlasmaC.
So if I understand the one included is not the last version, so I would like to install the correct one.
How can I install the last QtPlasmaC version? And, I did not understand, are there two locations where QtPlasmaC is?
Where is the most recent one and how to install it please?
Thanks to all in advance!
Alberto.
Thank you!
Alberto.
Thank you!
- jazzkramer
- Topic Author
6 days 2 hours ago #350481
by jazzkramer
maybe I found some answer about installation here
buildbot.linuxcnc.org/
...I'm reading. I was editing my previous post but... there something wrong and only the first part of my previous post is showing in the edit window... so I posted this one...
6 days 1 hour ago #350482
Yeah, our editor gets flummoxed by smileys, so it does not show anything after those.
The following user(s) said Thank You: jazzkramer
Time to create page: 0.059 seconds
