It's me or it's a bug?
5 days 6 hours ago - 5 days 6 hours ago #350484 by jazzkramer
Replied by jazzkramer on topic It's me or it's a bug?
Thanks , so I will not use emoticons jejeje.
So, follow up:
I will install as soon as possible the last version from...  instructions buildbot.linuxcnc.org/
so maybe errors are already corrected...
In the meantime, I'm attaching the gcode as modified by the "convers" in my QtPlasmaC. I saw I don't have the original produced by SheetcamTNG, I saved this on that one, so I only have this one (that is the one I was using).
About the error n 2, the "cutting in the air", while finishing the job (it's for a cantilever in my "borning shop"), I discovered the error is
when I press my custom button "Goto last X0Y0" before the Z axis finishes to reach the "idle height" after finishing a cut.
The button is a G0 X0 Y0 only (or it has Z0 as well? I have to check).
If I wait the Z axis to be at the idle height before pressing that button, the next cut properly works.
Bye, thanks,
have a nice day!
It did not attach the gcode, so I put it here:
;     file name: V2_Buco singolo.ngc
; date and time: Sun Oct 25 2026    01:44:24 PM
; postprocessor: LinuxCNC PlasmaC.scpost rev: 0.5
;begin pre-amble
 G21 (units: metric)
 G40 (cutter compensation: off)
 G90 (distance mode: absolute)
 M52 P1 (adaptive feed: on)
 M65 P2 (enable THC)
 M65 P3 (enable torch)
 M68 E3 Q0 (velocity 100%)
 G64 P0.254 Q0.025 (tracking tolerances: 0.254mm)
#<holes>      = 2
#<h_velocity> = 60
#<h_diameter> = 32
#<oclength>   = 4
;end pre-amble
;begin material setup
 T0 M6 (select plasma tool)
 G43 H0 (apply tool offsets)
 M190 P18 (plasma, mield steel + zinc 2mm material)
 M66 P3 L3 Q2 (wait for valid change)
 F#<_hal[plasmac.cut-feed-rate]>
;end material setup
 G0 X24.49 Y12.151
 M3 $0 S1 (plasma start)
 M67 E3 Q100
 G3 X17.928 Y15.211 I-4.811 J-1.751
 G1 X3.833 Y10.081
 G3 X7.167 Y0.919 I1.667 J-4.581
 G1 X35.358 Y11.18
 G3 X32.023 Y20.342 I-1.667 J4.581
 G1 X17.928 Y15.211
 M5 $0 (plasma end)
 ;begin post-amble
 M65 P2 (enable THC)
 M5 $-1 (backup stop)
 ;end post-amble
 ;begin statistics
 ;Pierces = 1
 ;   Cuts = 1,    Length = 98.67mm
 ;end statistics
 M30 (end program)
Last edit: 5 days 6 hours ago by jazzkramer.
Time to create page: 0.278 seconds
