- Hardware & Machines
- Pick and Place
- upward camera for position and rotation correction using opencv, available?
- itsme
- Thank you received: 21
20 Nov 2022 11:57 #257158
by itsme
upward camera for position and rotation correction using opencv, available? was created by itsme
Hello all!
I want to build a machine to batch measure LED properties using LinuxCNC. I can not use openPNP because i have some mesa hardware i want to use.
Is there any working macro/code/plugin available to measure the rotation and position of the LED held by the nozzle using a camera and correct them?
Any kind of help is highly appreciated!
- Thank you received: 2176
21 Nov 2022 15:04 #257221
Replied by Aciera on topic upward camera for position and rotation correction using opencv, available?
Have you looked at Dmitry's PnP project? Uses LinuxCNC and OpenCV maybe you can glean some information from the files on his github page_
github.com/yur7aev/linuxpnp
The following user(s) said Thank You: tommylight, my1987toyota, itsme
- my1987toyota
- Thank you received: 448
21 Nov 2022 17:34 #257239
by my1987toyota
Replied by my1987toyota on topic upward camera for position and rotation correction using opencv, available?
one thing to keep in mind is Dmitry's code is in python 2 unless he updated it.
The following user(s) said Thank You: itsme
- itsme
22 Nov 2022 07:09 #257305
by itsme
Replied by itsme on topic upward camera for position and rotation correction using opencv, available?
Thank you! I will have a look and test...
- Pick and Place
Time to create page: 0.079 seconds
