Alphacam post
18 Jun 2018 12:35 #112538 by Toolman321
Alphacam post was created by Toolman321
This question has been asked before but quite some time ago, does anyone have a post processor for linuxcnc for Alphacam
Please?
21 Jun 2018 05:26 #112699 by Yannis
Replied by Yannis on topic Alphacam post
hi
i use a 3 axis mach 3 mm with additional G 64 P
Use it at your own risk (be very careful)
send me your email
10 Nov 2019 21:35 #150076 by giovanni61
Replied by giovanni61 on topic Alphacam post
hello, I'm looking for a PP alphacam for linuxcnc. I saw that you use mach3 PP for linuxcnc, I also have a 3 axis. I already know how artcam but I would like to learn Alphacam. Could you help me? Could you send me your PP? I am a real goat and I am not able to write a PP. You apologize for my written English, I am Italian and I'm not know English well. Thank you very much and sorry for the inconvenience. bye
11 Nov 2019 12:07 #150102 by pl7i92
Replied by pl7i92 on topic Alphacam post
hi
alphacam suports almost every iso standard output for HAAS Fanuc also simpo,e mashines like mach,eding,nC so just use one of them
and get the INI Sartupcode set your Basics
then you are fine of a standard use
the cycles like pocket/rec/circle will not work at all on the linuxcnc
even isoPath postprocessor of alphacam is a good way to just mill a part
11 Nov 2019 12:51 #150108 by giovanni61
Thanks a lot for the answer. I found the Alpha_Router_Posts file for mach3 in the linuxcnc forum and I would like to use it with alphacam for linuxcnc. Do I need to change something to convert a PP txt (mach3) to ngc (liunuxcnc)? I don't understand anything about PP, could you explain in simple words what exactly should I do? regards
11 Nov 2019 14:43 #150116 by pl7i92
hi you can use this post without change
only the line 27 for startup code woudt be good to have G64 P0.01 or G61 inside
But i guesed arlyer this woudt be the same to be inside INI RS232_STARTUP_code
just test it out if you arew fine with the output
some dont like the view of the gcode as opuitputed in O format
but it will run
11 Nov 2019 15:05 #150121 by giovanni61
you are very kind. As I wrote, I've been learning alphacam recently. As soon as I am able, I will make a test file using this PP and I will update you. Thanks for your help. regards
12 Nov 2019 14:56 #150207 by giovanni61
Dear friend, I am here again. I ran a test with PP for mach3 and when I run the work on the cnc, I get an error: the program goes beyond the lower limits on the Z axis. So I used the generic PP for acam pantograph and changing the extension of the file and adding instructions the program is executed. Can you tell me what I have to change in PP mach3? Thanks. Regards
13 Nov 2019 05:51 #150267 by Yannis
hi
i think that your problem is in the ini file in the axis limits
13 Nov 2019 10:19 #150281 by giovanni61
ok, I'll try to change them. But I don't understand why the cnc works with the generic PP of alphacam and that of artcam that I've always used. I would have been satisfied even to use the generic PP for acam pantograph but it is too limited, in the file the G instructions for starting and ending the program are not generated. Thanks again for your availability. I will let you know. regards
Time to create page: 0.197 seconds
