Solidcam/Solidprobe
7 years 11 months ago #121424 by biqut2
Solidcam/Solidprobe was created by biqut2
Just wanted to chime in to say I've been using ncgui macros for probing for a while now but on a whim decided to start adding LinuxCNC compatible probing routines into my Solidcam postprocessor. I've spent an afternoon tirelessly typing away at the keyboard. If anyone is interested I'm happy to share and give back to the community. Also, proofreading to correct what I am sure are numerous typos is always a good thing too. Last but not least, if anyone is knowledgeable and knows of a more efficient way to write/organize the code that can't hurt either.
7 years 11 months ago #121453 by tommylight
Replied by tommylight on topic Solidcam/Solidprobe
You should post it here, someone might find it useful and help with it.
Thank you.
7 years 11 months ago #121468 by biqut2
Replied by biqut2 on topic Solidcam/Solidprobe
I definitely will. It'll be this afternoon before I can get to my laptop again.wasnt sure if it'd be better to just copy and past the code or upload it to a repository for editing.
7 years 11 months ago - 7 years 11 months ago #121507 by biqut2
Here is what I typed up yesterday. Got out to shop to test some of it tonight and the z touch, x touch, and y boss work as expected. They had a few typos that I had to correct so I fully expect there to be others as well.
EDIT: 2018/11/28 updated code
;------------------- LINUXCNC 2.7 - PROBE SECTION BEGIN @start_probe ;feed_rate defined in solidcam, change other values to suit probe_feed_rate = feed_rate search_feed_rate = 15 rapid_feed_rate = 60 latch_distance = 0.050 if bTlchg spin = 0 call @usr_ct bTlchg = false endif endp ;------------------- @misc_act ;message endp ;------------------- @move_prb {nl,'(Move Probe)'} {nl,'G01 X'xpos' Y'ypos' Z'zpos' F'rapid_feed_rate} {nl,''} endp ;------------------- @line_prb {nl,'(Line-up Probe)'} {nl,'G38.3 X'xpos' Y'ypos' Z'zpos' F'search_feed_rate} {nl,''} endp ;------------------- @prb_cyc_xyz_plan if ProbeCycle eq 'PRB_X_PLANE' and ActionProbeType eq 1 {nl,'(Probing X Plane)'} if PRB_Dir eq -1 {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420+'latch_distance'] Y'ypos' Z'zpos' F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'probe_feed_rate' (Probing)'} {nl,'G10 L20 P['mac_number'-1] X[#5061+#4002] (Updating Postion)'} endif if PRB_Dir eq 1 {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420-'latch_distance'] Y'ypos' Z'zpos' F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'probe_feed_rate' (Probing)'} {nl,'G10 L20 P['mac_number'-1] X[#5061-#4003] (Updating Postion)'} endif endif if ProbeCycle eq 'PRB_Y_PLANE' and ActionProbeType eq 1 {nl,'(Probing Y Plane)'} if PRB_Dir eq -1 {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'search_feed_rate' (Searching)'} {nl,'G01 X'xpos' Y[#5421+'latch_distance'] Z'zpos' F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'probe_feed_rate' (Probing)'} {nl,'G10 L20 P['mac_number'-1] Y[#5062+#4004] (Updating Postion)'} endif if PRB_Dir eq 1 {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'search_feed_rate' (Searching)'} {nl,'G01 X'xpos' Y[#5421-'latch_distance'] Z'zpos' F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'probe_feed_rate' (Probing)'} {nl,'G10 L20 P['mac_number'-1] Y[#5062-#4005] (Updating Postion)'} endif endif if ProbeCycle eq 'PRB_Z_PLANE' and ActionProbeType eq 1 {nl,'(Probing Z Plane)'} {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'search_feed_rate' (Searching)'} {nl,'G01 X'xpos' Y'ypos' Z[#5422+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' Y'PRB_TP1_Y' Z'PRB_TP1_Z' F'probe_feed_rate' (Probing)'} {nl,'G10 L20 P['mac_number'-1] Z#5063 (Updating Postion)'} endif {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl,''} endp ;------------------- @prb_cyc_bos_pckt if ProbeCycle eq 'PRB_BOSS' and ActionProbeType eq 1 and PRB_AlongAxis eq 'X' {nl,'(Probing Boss Along X)'} {nl,'G38.3 X['PRB_TP1_X'-'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP1_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 X'PRB_TP1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_negative> = [#5061+#4003]'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 X['PRB_TPX1_X'+'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP1_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 X'PRB_TPX1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TPX1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_positive> = [#5061-#4002]'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 X[[#<x_negative>+#<x_positive>]/2] F'rapid_feed_rate' (Move Probe)'} {nl,'G10 L20 P['mac_number'-1] X'xhpos' (Updating Position)'} {nl, ''} endif if ProbeCycle eq 'PRB_BOSS' and ActionProbeType eq 1 and PRB_AlongAxis eq 'Y' {nl,'(Probing Boss Along Y)'} {nl,'G38.3 Y['PRB_TPY2_Y'+'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP2_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_positive> = [#5062-#4004]'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 Y['PRB_TP2_Y'-'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP2_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 Y'PRB_TP2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TP2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_negative> = [#5062+#4005]'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 Y[[#<y_negative>+#<y_positive>]/2] F'rapid_feed_rate' (Move Probe)'} {nl,'G10 L20 P['mac_number'-1] Y'yhpos' (Updating Position)'} {nl, ''} endif if ProbeCycle eq 'PRB_BOSS' and ActionProbeType eq 1 and PRB_AlongAxis eq 'XY' {nl,'(Probing Boss Along X)'} {nl,'G38.3 X['PRB_TP1_X'-'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP1_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 X'PRB_TP1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_negative> = [#5061+#4003]'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 X['PRB_TPX1_X'+'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP1_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 X'PRB_TPX1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TPX1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_positive> = [#5061-#4002]'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 X[[#<x_negative>+#<x_positive>]/2] F'rapid_feed_rate' (Move Probe)'} {nl,'G10 L20 P['mac_number'-1] X'xhpos' (Updating Position)'} {nl, ''} {nl,'(Probing Boss Along Y)'} {nl,'G38.3 Y['PRB_TPY2_Y'+'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP2_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_positive> = [#5062-#4004]'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 Y['PRB_TP2_Y'-'PRB_RetractDist'] F'rapid_feed_rate' (Move Probe)'} {nl,'G38.3 Z'PRB_TP2_Z' F'search_feed_rate' (Line-up Probe)'} {nl,'G38.2 Y'PRB_TP2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TP2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_negative> = [#5062+#4005]'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G01 Z'clearance_plane' F'rapid_feed_rate' (Clearance Move)'} {nl, ''} {nl,'G38.3 Y[[#<y_negative>+#<y_positive>]/2] F'rapid_feed_rate' (Move Probe)'} {nl,'G10 L20 P['mac_number'-1] Y'yhpos' (Updating Position)'} {nl, ''} endif if ProbeCycle eq 'PRB_POCKET' and ActionProbeType eq 1 and PRB_AlongAxis eq 'X' {nl,'G38.2 X'PRB_TPX1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TPX1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_positive> = [#5061+#4003]'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.2 X'PRB_TP1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_negative> = [#5061-#4002]'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.3 X[[#<x_negative>+#<x_positive>]/2] F'rapid_feed_rate' (Move Probe)'} {nl,'G10 L20 P['mac_number'-1] X'xhpos' (Updating Position)'} {nl, ''} endif if ProbeCycle eq 'PRB_POCKET' and ActionProbeType eq 1 and PRB_AlongAxis eq 'Y' {nl,'(Probing Pocket Along Y)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_positive> = [#5062+#4005]'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.2 Y'PRB_TP2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TP2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_negative> = [#5062-#4004]'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.3 Y[[#<y_negative>+#<y_positive>]/2] F'rapid_feed_rate' (Protected Move)'} {nl,'G10 L20 P['mac_number'-1] Y'yhpos' (Updating Position)'} {nl, ''} endif if ProbeCycle eq 'PRB_POCKET' and ActionProbeType eq 1 and PRB_AlongAxis eq 'XY' {nl,'(Probing Pocket Along X)'} {nl,'G38.2 X'PRB_TPX1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TPX1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_positive> = [#5061+#4003]'} {nl,'G01 X[#5420-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.2 X'PRB_TP1_X' F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X'PRB_TP1_X' F'probe_feed_rate' (Probing)'} {nl,'#<x_negative> = [#5061-#4002]'} {nl,'G01 X[#5420+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.3 X[[#<x_negative>+#<x_positive>]/2] F'rapid_feed_rate' (Move Probe)'} {nl,'G10 L20 P['mac_number'-1] X'xhpos' (Updating Position)'} {nl, ''} {nl,'(Probing Pocket Along Y)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TPY2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_positive> = [#5062+#4005]'} {nl,'G01 Y[#5421-'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.2 Y'PRB_TP2_Y' F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y'PRB_TP2_Y' F'probe_feed_rate' (Probing)'} {nl,'#<y_negative> = [#5062-#4004]'} {nl,'G01 Y[#5421+'latch_distance'] F'rapid_feed_rate' (Retracting)'} {nl, ''} {nl,'G38.3 Y[[#<y_negative>+#<y_positive>]/2] F'rapid_feed_rate' (Protected Move)'} {nl,'G10 L20 P['mac_number'-1] Y'yhpos' (Updating Position)'} {nl, ''} endif endp ;------------------- @prb_cyc_cor ;WORKING {nl,'(Probing Corner)'} {nl,'G38.3 X[[#5420+'PRB_RetractDist_X'+'PRB_DX1']*'PRB_Dir_X'] F'search_feed_rate' (Protected Move)'} {nl,'G38.2 Y[#5421+['PRB_RetractDist_Y'*'PRB_Dir_Y']] F'search_feed_rate' (Searching)'} {nl,'G01 Y[#5421-['latch_distance'*'PRB_Dir_Y']] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 Y[#5421+['PRB_RetractDist_Y'*'PRB_Dir_Y']] F'probe_feed_rate' (Probing)'} {nl,'G10 L20 P['mac_number'-1] Y[#5062-#4005] (Updating Postion)'} {nl,'G01 X'xpos' Y'ypos' Z'zpos' F'search_feed_rate} {nl,''} {nl,'G38.3 Y[[#5421+'PRB_RetractDist_Y'+'PRB_DY1']*'PRB_Dir_Y'] F'search_feed_rate' (Protected Move)'} {nl,'G38.2 X[#5420+['PRB_RetractDist_X'*'PRB_Dir_X']] F'search_feed_rate' (Searching)'} {nl,'G01 X[#5420-['latch_distance'*'PRB_Dir_X']] F'rapid_feed_rate' (Retracting)'} {nl,'G38.2 X[#5420+['PRB_RetractDist_X'*'PRB_Dir_X']] F'probe_feed_rate' (Probing)'} {nl,'G10 L20 P['mac_number'-1] X[#5061-#4003] (Updating Postion)'} {nl,'G01 X'xpos' Y'ypos' Z'zpos' F'search_feed_rate} {nl,''} endp ;------------------- @prb_cyc_hol_cyl ;TODO endp ;------------------- @prb_cyc_angle ;TODO endp ;------------------- @end_probe {nl,'(End Probing)'} endp ;------------------- LINUXCNC 2.7 - PROBE SECTION END
Last edit: 7 years 11 months ago by biqut2.
4 years 9 months ago #233535 by ut3ge
Replied by ut3ge on topic Solidcam/Solidprobe
Everything works great, thank you for your work! Have you printed the functions for measuring holes and arcs yet?
@prb_cyc_hol_cyl & @prb_cyc_angle??? These features are sorely lacking.
Time to create page: 0.214 seconds
