CAMWorks Post for LInuxcnc
11 Jun 2021 17:22 #211817 by CaspianCmonster
CAMWorks Post for LInuxcnc was created by CaspianCmonster
Hi I am trying to modify the Fanuc 11m post in CAMworks (Solidworks CAM) using the CAMWorks post tool and I am not having any luck. Does anyone have experience with post modification?
I am just trying to add a delay for the spindle to ramp up before it start cutting (G4 P15) and I think I found the place to do that but the resulting gcode doesn't reflect the change. I am not sure I am using the correct syntax etc.
thanks
Luke
14 Jun 2021 06:31 #212001 by CaspianCmonster
Replied by CaspianCmonster on topic CAMWorks Post for LInuxcnc
I found a solution to add a delay which is too put the G04 command in the first rapid down section and recompile.
:T:<N><G!:04> P13<EOL>
Time to create page: 0.076 seconds
