- Thank you received: 48
SolidWorks for makers, post processor for LinuxCNC?
- ikkuh
- Topic Author
4 years 2 months ago #250529
by ikkuh
SolidWorks for makers, post processor for LinuxCNC? was created by ikkuh
I am trying to use nc shop floor, the cam software that comes with SolidWorks for makers. But what postprocessor should I use?
The shop floor program is difficult enough, it's totally illogical, and now I am not sure what output to use.
Can anybody help?
Can anybody help?
4 years 2 months ago #250555
Replied by rodw on topic SolidWorks for makers, post processor for LinuxCNC?
one of my mates has a license to Fusion 360 for the cam part.
- ikkuh
- Topic Author
4 years 2 months ago #250560
by ikkuh
Replied by ikkuh on topic SolidWorks for makers, post processor for LinuxCNC?
I use the excelent Path workbench in FreeCAD now to make stuff. I design in SolidWorks and export a step file. The step file I use in FC to make code for LinuxCNC.
- gene_weber
- Thank you received: 19
4 years 2 months ago #250588
by gene_weber
Replied by gene_weber on topic SolidWorks for makers, post processor for LinuxCNC?
@ikkuh, I'm new to CNC, in the process of setting up my first mill. I also draw parts in SolidWorks (3DEXPERIENCE for Makers). I'm trying to figure out the cleanest low $$ path to get from the part drawing to GCODE to run the mill.
I have used FreeCAD in the past. I have zero experience with LinuxCNC. So you import an STL into FreeCAD and use Path Workbench. What do you output from Path Workbench? I have my mill, but have not selected controller, SW, or steppers/servos yet. I'm trying to understand the flow better before I spend $$.
Thanks for any insights.
4 years 2 months ago #250592
Replied by tommylight on topic SolidWorks for makers, post processor for LinuxCNC?
Ikkuh mentioned STEP files, not STL, and the Path workbench outputs gcode ready for use with cnc machines, in this case for use with LinuxCNC.
I used lately FreeCAD to design a new cnc engraver, after a bit of getting used to i really like it, but i use it for exporting STL and 3D printing the parts.
Did not have a chance to check Path workbench yet, mostly becouse i have to build a mill first.
Assembly3 workbench works nicely.
- Silverback
- Thank you received: 5
1 year 7 months ago #324678
by Silverback
Replied by Silverback on topic SolidWorks for makers, post processor for LinuxCNC?
I know I am a bit late to the party, but there's a NC Shop Floor Programmer postprocessor for LinuxCNC on the SFP wiki.
r1132100503382-eu1-3dswym.3dexperience.3...ftfpxcTGarZ6eplZQaew
Also, SFP includes ICAM Foundation for developing your own postprocessors.
Hope this helps someone in the future
1 year 7 months ago #324692
The above link is to a login page, so why is that posted here?
I see no reason for it as this is open source forum, while that is not open source.
1 year 7 months ago #324721
The link takes you to a solidworks Makers page with a postprocessor. I guess if you are using Solidworks you might have a use for it and the required login.The above link is to a login page, so why is that posted here?
- bnet
1 year 7 months ago #324939
by bnet
Replied by bnet on topic SolidWorks for makers, post processor for LinuxCNC?
If the NC Shop Floor program has some default post processors, try any of them designed for Fanuc controls. Those have been working for me on different CAM software so maybe it will work for you. Sometimes you need to edit something in the code but it's usually just in the setup code or similar.
Time to create page: 0.065 seconds
