- GCode and Part Programs
- CAD CAM
- Post Processors
- VisualCAD/CAM - what post processor should i pick to use g-code in LinuxCNC?
- Boogie
- Thank you received: 9
12 Dec 2023 02:57 #287919
by Boogie
VisualCAD/CAM - what post processor should i pick to use g-code in LinuxCNC? was created by Boogie
Guys,
i need help. Please, tell me, as i'm lost - my friend is buying Visual CAD/CAM and the seller is asking him what post processor to attach to the software. He is going to use LinuxCNC with Mesa cards to control his machine. Which post processor is ok for this setup?
Thank you,
Boogie
Thank you,
Boogie
- timo
- Thank you received: 61
12 Dec 2023 03:13 #287920
by timo
Replied by timo on topic VisualCAD/CAM - what post processor should i pick to use g-code in LinuxCNC?
How about Linux CNC Post processor?
Given that some software has this it might be really available or not?
- Mecanix
- Thank you received: 229
12 Dec 2023 03:41 - 12 Dec 2023 03:42 #287922
by Mecanix
Replied by Mecanix on topic VisualCAD/CAM - what post processor should i pick to use g-code in LinuxCNC?
Overhaul motion is G-Code Standard for Linuxcnc. Therefore if your friend is forced to pick a controller-specific postprocessor, I'd recommend a "Fanuc System B" to start with. Be mindful that all postprocessors inevitably require modifications... all depending on the machine-tool features, some more than others...
Last edit: 12 Dec 2023 03:42 by Mecanix.
- CAD CAM
- Post Processors
Time to create page: 0.188 seconds
