ECAM 5 POST Processors
- gravedigger
04 Nov 2025 09:00 #337797
by gravedigger
ECAM 5 POST Processors was created by gravedigger
I’m just getting started with LinuxCNC and have switched over from Mach4. I’ve been using the Italian ECAM 5 software and would like to continue using it. How different is the G-code between Mach and LinuxCNC? What are the main differences?
- Thank you received: 1482
04 Nov 2025 11:09 #337804
Replied by Todd Zuercher on topic ECAM 5 POST Processors
The G-code is not very different and for the most part should work.
The biggest difference is that you should set a path blending tolerance at the start of the g-code in Linuxcnc. This will be a g-code line something like G64 P0.001 Q0.001.
Other differences will be with sub program calls and O-codes and canned cycles. But unless you are doing parametric g-code (unlikely with CAM produced code) it won't matter.
Linuxcnc's G-code is also similar to a lot of Fanuc code, and with similar exceptions as with Mach3.
- billykid
- Thank you received: 83
14 Nov 2025 09:13 - 14 Nov 2025 09:47 #338347
by billykid
Replied by billykid on topic ECAM 5 POST Processors
I use ecam, as soon as I can I'll send you mine, it works well.
Last edit: 14 Nov 2025 09:47 by billykid.
- Miller Turner
28 Jun 2026 14:05 #347369
by Miller Turner
Replied by Miller Turner on topic ECAM 5 POST Processors
Hi All,
Have you been using E-CAM for mill or lathe?
- billykid
29 Jun 2026 11:50 #347388
by billykid
I used eCAM 5 and I'm happy with it, now I got the new 6 for a small CNC. I don't use it much, it's not my job, but the lathe part, according to a friend who uses it on a CNC lathe that we retrofitted together, is excellent.
- Becksvill
- Thank you received: 115
11 Sep 2026 08:19 #349568
by Becksvill
Replied by Becksvill on topic ECAM 5 POST Processors
I also use E cam
i have a post i modified main things i had to fix are threading g33.
everything else in the post i have checked works well i use it on a production cnc lathe running linuxcnc.
Ecam is absolutely awesome. way better than fusion 360 lathe cam in my opinion and i used both for 2 years
my post currently still has one issue left. when using g97 constant spindle speed the post still outputs a D value for max speed. and linuxcnc throws a error on this so currently i just delete that code from the file. but it's on the list to fix at some stage.
- tuxcnc
- Thank you received: 58
11 Sep 2026 08:48 #349570
by tuxcnc
Although simple code from a simple postprocessor will be executed correctly on both machines, this should be considered the exception, not the rule.
In extreme cases, running a foreign code will result in damage to the machine or injury to the operator, because there are codes that are written identically but executed differently. Such code will not generate an error, only unexpected movement.
Replied by tuxcnc on topic ECAM 5 POST Processors
Basically, you should consider the g-code for Mach4 and LinuxCNC to be incompatible and under no circumstances run programs from one machine on the other.How different is the G-code between Mach and LinuxCNC? What are the main differences?
Time to create page: 0.162 seconds
