- Thank you received: 784
giz wrote: I realized that shortly after posting, so I took a stab at it and made some progress. I currently have the "Load Spindle" button working, but initiating a M6 command (either in MDI, GUI, or GCode) just causes the control to "hang" as if it's trying to do something. It puts the control into a state that is not idle, but I can't interact with anything until I hit the "Stop" button. I'm a little blind because I don't know what it is hanging up on.
My best guess is that something isn't right about my M6 command.
I'm loading tools by hand right now, so I'm posting g-code for just 1 tool at a time and just want the Z offsets handled automatically. No ATC movements or axis movements associated with M6.
Chipping away at it...
anfänger wrote: Sice there is still the limit if 56 tools ins the tool table I was happy to see that there is a tool library in probe basic.
But to be honest I don't know how to use it.
Is it already developed or still "under construction"?
Thanks Patrick
Lcvette wrote:
still under construction at the moment but low on the list of priorities unfortunately, it will need some pretty heavy duty work i think to get up and running. but if anyone out there who knows database coding and who could help to set it up that would be awesome. there was a lot of discussion about making the fusion tool table and linuxcnc tool library updated together, that would be pretty sweet ithink! coders needed!!
