- Thank you received: 489
How to add HAL pins to QtPyVCP?
- scotta
7 years 6 months ago - 7 years 6 months ago #130869
by scotta
Replied by scotta on topic How to add HAL pins to QtPyVCP?
Kurt,
Again fantastic work. With the HAL functionality you have now truly created a fully customisable VCP environment!
A really simple test.
custom_postgui.hal
Result:
Nice!!
Scott
| HalSlider - objectName: | bed_temp_SP | |
| HalLabel - objectName: | bed_temp_PV | |
| HalLCDNumber - objectName: | bed_temp_SP_LCD |
custom_postgui.hal
net bed-temp qtpyvcp.bed-temp-SP.out-f => qtpyvcp.bed-temp-PV.in
net bed-temp => qtpyvcp.bed-temp-SP-LCD.in-f
Result:
Nice!!
Scott
Last edit: 7 years 6 months ago by scotta.
The following user(s) said Thank You: KCJ
- KCJ
- Thank you received: 267
7 years 6 months ago #130870
by KCJ
Replied by KCJ on topic How to add HAL pins to QtPyVCP?
Scott, glad the HAL widgets work for you!
I like your idea of the combined setpoint slider and readout, I'll have a go at making that.
Cheers,
Kurt
Cheers,
Kurt
The following user(s) said Thank You: scotta
- scotta
7 years 6 months ago #130871
by scotta
Thanks Kurt,
The only other thing that would be really cool would be a HAL plot widget. For my 3D Printer UI this would be allow the trending of temperatures over time, something other Printer UI's have... I really need to learn more Python.
BR
Scott
BR
Scott
- KCJ
7 years 6 months ago #130882
by KCJ
A HAL plot widget would be useful for all sorts of things.
PyQtGraph
is a very capable PyQt based plotting toolkit that would be easy to integrate with QtPyVCP. There are other parts of QtPyVCP I need to concentrate on now, but if you would like to play with adding a HAL plot widget I would be more than happy to help guide you.
Cheers,
Kurt
Cheers,
Kurt
- scotta
7 years 6 months ago #130930
by scotta
Hi Kurt,
Thanks. I keen to learn some more python so that would be great. Probably the simplest way would for the HAL Plot Widget to create it's own pins and use the custom_postgui.hal file to net the required connections. Then how to format range and spans... First step though is to understand the widget framework.
BR
Scott
BR
Scott
Moderators: KCJ, Lcvette
Time to create page: 0.660 seconds
