QTpyvcp Error: Sim will not open
- billnixon
27 Sep 2019 03:50 #146325
by billnixon
QTpyvcp Error: Sim will not open was created by billnixon
I am not able to open a sim with a qtpyvcp gui. I am following JT's instructions here:
Getting Started
Mint 19.2
LinuxCNC 2.8
4.19.1-rt3 #1 SMP PREEMPT RT
Here is what the error window says:
Qtvcp encountered an error. The following information may be useful in troubleshooting: LinuxCNC Version :2.8.0~pre1
QTvcp ERROR! Message #1
File "/usr/bin/qtvcp", line 480, in <module>
APP = QTVCP()
File "/usr/bin/qtvcp", line 318, in __init__
window.load_extension(opts.usermod)
File "/usr/lib/python2.7/dist-packages/qtvcp/qt_makegui.py", line 156, in load_extension
methods,self.handler_module,self.handler_instance = self._load_handlers([handlerpath], self.halcomp,self)
File "/usr/lib/python2.7/dist-packages/qtvcp/qt_makegui.py", line 184, in _load_handlers
mod = __import__(basename)
File "/usr/share/qtvcp/screens/qtaxis/qtaxis_handler.py", line 13, in <module>
from qtvcp.lib.toolbar_actions import ToolBarActions
File "/usr/lib/python2.7/dist-packages/qtvcp/lib/toolbar_actions.py", line 20, in <module>
from qtvcp.widgets.dialog_widget import LcncDialog as Dialog
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/dialog_widget.py", line 30, in <module>
from qtvcp.widgets.macro_widget import MacroTab
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/macro_widget.py", line 86, in <module>
class CustomSVG(QtSvg.QSvgWidget):
NameError: name 'QtSvg' is not defined
In the "LinuxCNC terminated with an error" window it asks if python-opencv and python-pyqt5.qtsvg are installed.
They are not listed with pip list. Could they be installed somewhere else?
Any help would be much appreciated. Thanks in advance.
Getting Started
Mint 19.2
LinuxCNC 2.8
APP = QTVCP()
- Thank you received: 2173
27 Sep 2019 05:59 #146330
Replied by cmorley on topic QTpyvcp Error: Sim will not open
These errors are from qtvcp.
You mention pyqtvcp which is not the same project.
Which are you trying to use?
Chris
Chris
- billnixon
27 Sep 2019 11:55 - 27 Sep 2019 11:55 #146372
by billnixon
Replied by billnixon on topic QTpyvcp Error: Sim will not open
I'm sorry. I was loading the wrong sims. I meant to load a qtpyvcp sim. Probe basic does load.
Last edit: 27 Sep 2019 11:55 by billnixon.
- pl7i92
- Thank you received: 358
27 Sep 2019 14:45 #146398
by pl7i92
Replied by pl7i92 on topic QTpyvcp Error: Sim will not open
its always a miss of the naming on this tow projekts that people are facing on a newcommer Base
it will be soon clear if you run more into the system
Moderators: KCJ, Lcvette
Time to create page: 0.144 seconds
