QtPyVCP - status:current_line - Not Working
  • Donb9261
  • Donb9261's Avatar Topic Author
  • Elite Member
  • Elite Member
06 Jan 2020 23:03 #154180 by Donb9261
For some reason it appears status:current_line and status:read_line have the same value. I was trying to install a Status Label to refelct the current running line number and it shows the value related to the last line in the code.
Is this a known issue and is there a work around?
07 Jan 2020 19:36 #154240 by cmorley
Replied by cmorley on topic QtPyVCP - status:current_line - Not Working
know issue with linuxcnc - there is no work around.
It's because for linuxnc displays the line it is interpreting rather then the line it is actually running - they quickly can be different.
Chris
The following user(s) said Thank You: BigJohnT, KCJ, Donb9261
09 Jan 2020 00:52 #154374 by andypugh
Replied by andypugh on topic QtPyVCP - status:current_line - Not Working
if you need it, the hal pin motion.program-line is accurate.
You could display that, or read it with a hal component.
The following user(s) said Thank You: BigJohnT, Donb9261
  • Donb9261
  • Elite Member
  • Elite Member
09 Jan 2020 13:30 #154438 by Donb9261
Replied by Donb9261 on topic QtPyVCP - status:current_line - Not Working
status:motion_line works. Would provide same as hal pin.
The following user(s) said Thank You: KCJ
Moderators: KCJ, Lcvette
