Skip VCP Chooser at startup possible?
21 Jan 2020 09:55 - 21 Jan 2020 10:13 #155304 by MovT
Hello Forum.
I have the QtPyVCP installed like the development install howto. I want to skip the VCP Chooser and want to start an existing VCP "probe_basic" as example. In my .ini i only can supply DISPLAY=qtpyvcp.
I appreciate any hint.
Best,
Udo
Last edit: 21 Jan 2020 10:13 by MovT.
21 Jan 2020 13:48 - 21 Jan 2020 13:48 #155318 by Leon82
Replied by Leon82 on topic Skip VCP Chooser at startup possible?
Add the second line
Display =qtpyvcp
Vcp=probe_basic
Last edit: 21 Jan 2020 13:48 by Leon82.
The following user(s) said Thank You: TurBoss
21 Jan 2020 20:14 - 21 Jan 2020 20:15 #155356 by BigJohnT
Replied by BigJohnT on topic Skip VCP Chooser at startup possible?
Over at www.qtpyvcp.com you can see the ini options on this page .
Not sure if the ini entry names are case insensitive or not.
JT
Last edit: 21 Jan 2020 20:15 by BigJohnT.
22 Jan 2020 06:56 #155403 by MovT
Replied by MovT on topic Skip VCP Chooser at startup possible?
Thanks a lot!
I´ll try it out. Actually my controller rack is in a build state. If it´s ready i can start LCNC with 7i76E connected.
Thanls again!
26 Jan 2020 11:42 - 26 Jan 2020 11:42 #155790 by MovT
Thank you John and Leon.
VCP=probe_basic in the .ini file at the DISPLAY section works like a charme.
Best,
Udo
Last edit: 26 Jan 2020 11:42 by MovT.
The following user(s) said Thank You: KCJ
Moderators: KCJ, Lcvette
Time to create page: 0.740 seconds
