- User Interfaces
- Other User Interfaces
- QtPyVCP
- probe_basic wont start: ImportError: No module named stack [solved]
- anfänger
- Thank you received: 260
01 Mar 2020 11:23 - 04 Mar 2020 06:32 #158885
by anfänger
probe_basic wont start: ImportError: No module named stack [solved] was created by anfänger
I think I'm missing a module or some path is not right.
after reinstalling probe_basic I get following error:
has anyone some idea how to solve it?
Patrick
File "/home/igor/.local/bin/probe_basic", line 11, in <module>
load_entry_point('probe-basic', 'gui_scripts', 'probe_basic')()
File "/home/igor/linuxcnc/probe_basic/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/__init__.py", line 142, in run_vcp
launch_application(opts, config)
File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/vcp_launcher.py", line 78, in launch_application
loadWindows(config['windows'])
File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/vcp_launcher.py", line 211, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/vcp_launcher.py", line 205, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/home/igor/linuxcnc/probe_basic/probe_basic/probe_basic.py", line 23, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/widgets/form_widgets/main_window.py", line 43, in __init__
self.loadUi(ui_file)
File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/widgets/form_widgets/main_window.py", line 102, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/__init__.py", line 226, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/loader.py", line 72, in loadUi
return self.parse(filename, resource_suffix, basedir)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 1000, in parse
actor(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 807, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 262, in createWidget
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 482, in createLayout
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 525, in handleItem
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 253, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 217, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 106, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 131, in findQObjectType
w = module.search(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 115, in search
module = __import__(mname, {}, {}, (cls,))
Patrick
Last edit: 04 Mar 2020 06:32 by anfänger.
- hottabich
- Thank you received: 96
02 Mar 2020 18:45 #159011
by hottabich
Replied by hottabich on topic probe_basic wont start: ImportError: No module named stack
kcjengr.github.io/probe_basic/dev_install.html
Put it and there will be no mistake!
- Lcvette
- Thank you received: 782
04 Mar 2020 01:37 #159135
by Lcvette
patrick, the latest version 2.5 fixes that!
Replied by Lcvette on topic probe_basic wont start: ImportError: No module named stack
after reinstalling probe_basic I get following error:Traceback (most recent call last): File "/home/igor/.local/bin/probe_basic", line 11, in <module> load_entry_point('probe-basic', 'gui_scripts', 'probe_basic')() File "/home/igor/linuxcnc/probe_basic/probe_basic/__init__.py", line 20, in main qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE) File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/__init__.py", line 142, in run_vcp launch_application(opts, config) File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/vcp_launcher.py", line 78, in launch_application loadWindows(config['windows']) File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/vcp_launcher.py", line 211, in loadWindows window = _initialize_object_from_dict(window_dict) File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/vcp_launcher.py", line 205, in _initialize_object_from_dict return obj(*args, **kwargs) File "/home/igor/linuxcnc/probe_basic/probe_basic/probe_basic.py", line 23, in __init__ super(ProbeBasic, self).__init__(*args, **kwargs) File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/widgets/form_widgets/main_window.py", line 43, in __init__ self.loadUi(ui_file) File "/home/igor/linuxcnc/qtpyvcp/qtpyvcp/widgets/form_widgets/main_window.py", line 102, in loadUi uic.loadUi(ui_file, self) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/__init__.py", line 226, in loadUi return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/loader.py", line 72, in loadUi return self.parse(filename, resource_suffix, basedir) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 1000, in parse actor(elem) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 807, in createUserInterface self.traverseWidgetTree(elem) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree handler(self, child) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 262, in createWidget self.traverseWidgetTree(elem) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree handler(self, child) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 482, in createLayout self.traverseWidgetTree(elem) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree handler(self, child) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 525, in handleItem self.traverseWidgetTree(elem) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree handler(self, child) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 482, in createLayout self.traverseWidgetTree(elem) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree handler(self, child) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 525, in handleItem self.traverseWidgetTree(elem) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 785, in traverseWidgetTree handler(self, child) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 253, in createWidget self.stack.push(self.setupObject(widget_class, parent, elem)) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 217, in setupObject obj = self.factory.createQObject(clsname, name, args, is_attribute) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 106, in createQObject factory = self.findQObjectType(classname) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 131, in findQObjectType w = module.search(classname) File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 115, in search module = __import__(mname, {}, {}, (cls,)) ImportError: No module named stack
Patrick
The following user(s) said Thank You: KCJ, anfänger
- anfänger
04 Mar 2020 06:31 #159153
by anfänger
Replied by anfänger on topic probe_basic wont start: ImportError: No module named stack
Thanks after a new update it is working again!
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.251 seconds
