Installation problem with QtPyVCP (Buster)
05 Mar 2020 19:12 - 05 Mar 2020 19:13 #159272 by romeofox
Hello,
I have installed the dependencies and the python module via pip as described here (www.qtpyvcp.com/install/quick_start.html)
No errors were displayed.
Now I expected to find the corresponding sim configs here: ~/linuxcnc/configs/sim.qtpyvcp.
But no folder was generated.
I tried the installation with my user and as root, both did not work.
Is it known, is there a trick to it?
I use Debian Buster and LinuxCNC 2.9.
Best regards
Robert
Last edit: 05 Mar 2020 19:13 by romeofox.
05 Mar 2020 21:28 #159287 by andypugh
Replied by andypugh on topic Installation problem with QtPyVCP (Buster)
The sample configs get copied from the base install to your configs folder when you pick them in the config picker (expand the "sample configs" section.
05 Mar 2020 23:02 - 05 Mar 2020 23:03 #159291 by Lcvette
Replied by Lcvette on topic Installation problem with QtPyVCP (Buster)
Hello,
Best regards
Robert
what examples are you wanting to use?
Last edit: 05 Mar 2020 23:03 by Lcvette.
06 Mar 2020 13:00 #159325 by romeofox
Replied by romeofox on topic Installation problem with QtPyVCP (Buster)
Thanks for the help,
I have now actually found the folder qtdragon under qtvcp_screens with the setup i was looking for.
I expected a folder qtpyvcp.
Best regards
Robert
06 Mar 2020 16:47 #159340 by Lcvette
qtvcp is different than qtpyvcp...
10 Mar 2020 23:55 #159718 by BigJohnT
Replied by BigJohnT on topic Installation problem with QtPyVCP (Buster)
You can copy the examples from github.com/kcjengr/qtpyvcp/tree/master/examples to your linuxcnc/configs directory.
JT
The following user(s) said Thank You: KCJ
03 Apr 2020 21:13 #162609 by Haarie
Replied by Haarie on topic Installation problem with QtPyVCP (Buster)
Hello CnCBuddies,
I have the same issue Debian 9 (Stretch) / LinuxCNC 2.9 on an other fresh install.
Followed the Quick Start guide from Kurt till:
This will install QtPyVCP along with the examples, and will add QtPyVCP specific sim configs to ~/linuxcnc/configs/sim.qtpyvcp.
In LinuxCNC I don't see the QtPyVCP map in Sample Configurations/Sim/
Please how can I get the map back in the Sample Configurations with the Install?
Regards,
Haarie
04 Apr 2020 15:39 #162681 by KCJ
Haarie,
I just tested `$ pip install qtpyvcp` and it did install the sim.qtpyvcp directory in my ~/linuxcnc/configs directory as it should. But it seems like at least you and romeofox har having problems with it working.
Can you please uninstall qtpyvcp with `pip uninstall qtpyvcp` and then reinstall it with `pip install qtpyvcp --no-deps` and paste the output here? The --no-deps is just to limit the output to that from qtpyvcp since you already have the deps installed.
Thanks,
Kurt
04 Apr 2020 16:30 #162684 by KCJ
Haarie,
I just thought of something, could you trying installing with `pip install qtpyvcp --no-deps --no-cache-dir` and see if that works?
The following user(s) said Thank You: ronthomp
04 Apr 2020 21:42 #162706 by Haarie
Kurt, thank you for reply!
Running setup.py install for qtpyvcp ... done
Successfully installed qtpyvcp-0.3.7
Now the directory is there!
Moderators: KCJ, Lcvette
Time to create page: 0.183 seconds
