Installation problem with QtPyVCP (Buster)
6 years 7 months ago - 6 years 7 months ago #159272 by romeofox
Hello,
I have installed the dependencies and the python module via pip as described here ( www.qtpyvcp.com/install/quick_start.html )
No errors were displayed.
Now I expected to find the corresponding sim configs here: ~/linuxcnc/configs/sim.qtpyvcp.
But no folder was generated.
I tried the installation with my user and as root, both did not work.
Is it known, is there a trick to it?
I use Debian Buster and LinuxCNC 2.9.
Best regards
Robert
Last edit: 6 years 7 months ago by romeofox.
6 years 7 months ago #159287 by andypugh
The sample configs get copied from the base install to your configs folder when you pick them in the config picker (expand the "sample configs" section.
6 years 7 months ago - 6 years 7 months ago #159291 by Lcvette
romeofox wrote: Hello,
Best regards
Robert
what examples are you wanting to use?
Last edit: 6 years 7 months ago by Lcvette.
6 years 7 months ago #159325 by romeofox
Thanks for the help,
I have now actually found the folder qtdragon under qtvcp_screens with the setup i was looking for.
I expected a folder qtpyvcp.
Best regards
Robert
6 years 7 months ago #159340 by Lcvette
qtvcp is different than qtpyvcp...
6 years 7 months ago #159718 by BigJohnT
You can copy the examples from github.com/kcjengr/qtpyvcp/tree/master/examples to your linuxcnc/configs directory.
JT
The following user(s) said Thank You: KCJ
Moderators: KCJ, Lcvette
Time to create page: 0.341 seconds
