Installation problem with QtPyVCP (Buster)
6 years 6 months ago #162609 by Haarie
Hello CnCBuddies,
I have the same issue Debian 9 (Stretch) / LinuxCNC 2.9 on an other fresh install.
Followed the Quick Start guide from Kurt till:
This will install QtPyVCP along with the examples, and will add QtPyVCP specific sim configs to ~/linuxcnc/configs/sim.qtpyvcp.
In LinuxCNC I don't see the QtPyVCP map in Sample Configurations/Sim/
Please how can I get the map back in the Sample Configurations with the Install?
Regards,
Haarie
6 years 6 months ago #162681 by KCJ
Haarie,
I just tested `$ pip install qtpyvcp` and it did install the sim.qtpyvcp directory in my ~/linuxcnc/configs directory as it should. But it seems like at least you and romeofox har having problems with it working.
Can you please uninstall qtpyvcp with `pip uninstall qtpyvcp` and then reinstall it with `pip install qtpyvcp --no-deps` and paste the output here? The --no-deps is just to limit the output to that from qtpyvcp since you already have the deps installed.
Thanks,
Kurt
6 years 6 months ago #162684 by KCJ
Haarie,
I just thought of something, could you trying installing with `pip install qtpyvcp --no-deps --no-cache-dir` and see if that works?
The following user(s) said Thank You: ronthomp
6 years 6 months ago #162706 by Haarie
Kurt, thank you for reply!
Running setup.py install for qtpyvcp ... done
Successfully installed qtpyvcp-0.3.7
Now the directory is there!
Moderators: KCJ, Lcvette
Time to create page: 0.284 seconds
