Where do you find the Probe Basic Lathe VCP?
- helmholtz
26 Apr 2020 20:34 #165693
by helmholtz
Where do you find the Probe Basic Lathe VCP? was created by helmholtz
I followed the getting started guide and in the VCP chooser there is an option for Probe Basic, which is the 3-5 mill interface. The QtPyVCP website also shows a lathe interface but there don't seem to be any files associated with that.
What am I missing here? Thank!
- KCJ
- Thank you received: 267
26 Apr 2020 22:39 #165713
by KCJ
Replied by KCJ on topic Where do you find the Probe Basic Lathe VCP?
Hello,
The probe basic lathe files are still in the ProbeBasic repo, but they have been removed from the VCP list since they are not fully functional yet.
Cheers,
Kurt
Cheers,
Kurt
- helmholtz
27 Apr 2020 16:13 #165843
by helmholtz
Replied by helmholtz on topic Where do you find the Probe Basic Lathe VCP?
Thanks for the reply. It's by far the best looking lathe interface I've seen. I hope that you are able to continue working on releasing it.
The following user(s) said Thank You: KCJ
- KCJ
30 Apr 2020 00:12 #166176
by KCJ
Thank you! TurBoss and Lcvette have done a great job.
Lcvette is building a CNC lathe, so I'm sure it will be completed sooner or later.
Cheers,
Kurt
Cheers,
Kurt
- Lcvette
- Thank you received: 784
16 May 2020 12:07 #167958
by Lcvette
Thanks, we are working on it daily at the moment! and we need some lathe users who know cnc lather operation to pop in and help answer some questions us new to lathe guys are. currently we have some questions regarding how the css, feed per rev, feed per unit stuff should be setup, we also would like some lathe tool input on how the touch off thing should work etc and the tool table stuff. I am very familiar with mills but am fairly inexperienced when it comes to lathe controls so please if you have some knowledge that you can share and help us get it right, I am sure it would go alot faster to getting it finished and out in a user release!
Thanks all!
Chris
Replied by Lcvette on topic Where do you find the Probe Basic Lathe VCP?
Thanks all!
Chris
- vmihalca
- Thank you received: 22
18 May 2020 09:32 #168133
by vmihalca
Replied by vmihalca on topic Where do you find the Probe Basic Lathe VCP?
Hi, I have both a lathe and a mill, running linuxcnc, I might know the information you need. Also I'm a programmer, and I would like some customizations that I could probably do myself if I get some things explained!
- Becksvill
- Thank you received: 115
20 May 2020 10:31 #168361
by Becksvill
Replied by Becksvill on topic Where do you find the Probe Basic Lathe VCP?
Hey guys
I have been machining in different workshops for several years using lathes. Mainly using Fagor and semiens controls.
I have a big long list of suggested things that I really liked about those controls that would be good to get into linuxcnc
and I am about to retrofit my cnc lathe myself soon
So if I can help with suggestions just sing out.
is there a chat group somewhere where we could take a look at the current progress and suggest any missing functions?
I am currently just getting to grips with QYPYVCP myself or I would try help out more.
I love what you guys are doing and definitely want to learn how to build the new gui's.
there are so many applications for them
Andrew
Andrew
- Thank you received: 7487
20 May 2020 10:41 #168363
Replied by tommylight on topic Where do you find the Probe Basic Lathe VCP?
Yes, it is @hazzy , but i might be wrong since it's been some time that i did not go there.
- Becksvill
20 May 2020 10:52 #168365
by Becksvill
tommy you might have to baby sit me here
I have never used IRC or anything like it
just a little bit stuck
Andrew
Andrew
20 May 2020 11:11 #168366
Moderators: KCJ, Lcvette
Time to create page: 0.101 seconds
