Probe basic jog wheel MPG help
- harindugamlath
- Thank you received: 19
20 Jun 2020 05:38 #172152
by harindugamlath
Probe basic jog wheel MPG help was created by harindugamlath
I'm having a bit of a problem with probe basic due to the lack of hal pins. I had my MPG working with axis gui. I used the axis selection and the jog increment from the axisgui hal pins to select the jog axis and the increment.
Now when i switch to probe basic I don't get any hal pins to work with. Can i add custom hal pins?
What files do i need to edit?
I'm running 5i25 with 7i76d and a 100ppr mpg.
I'm a newbie to linuxcnc any help is appreciated.
The following user(s) said Thank You: Lcvette
- Thank you received: 7504
22 Jun 2020 09:57 #172349
Replied by tommylight on topic Probe basic jog wheel MPG help
Bumping this as it might have been missed by someone who can help.
The following user(s) said Thank You: Lcvette, harindugamlath
- Lcvette
- Thank you received: 784
22 Jun 2020 10:04 #172352
by Lcvette
Replied by Lcvette on topic Probe basic jog wheel MPG help
not sure of this helps, but this is my mpg hal file:
#file name mpg.hal
loadrt mux4 count=1
loadrt ilowpass
addf mux4.0 servo-thread
addf ilowpass.0 servo-thread
setp ilowpass.0.scale 100
setp ilowpass.0.gain 0.01
setp joint.0.jog-accel-fraction .5
setp joint.1.jog-accel-fraction .5
setp joint.2.jog-accel-fraction .5
setp joint.3.jog-accel-fraction .5
net x-jog-select joint.0.jog-enable <= hm2_7i92.0.7i77.0.0.input-20
net y-jog-select joint.1.jog-enable <= hm2_7i92.0.7i77.0.0.input-21
net z-jog-select joint.2.jog-enable <= hm2_7i92.0.7i77.0.0.input-22
net a-jog-select joint.3.jog-enable <= hm2_7i92.0.7i77.0.0.input-23
net x10 hm2_7i92.0.7i77.0.0.input-26 => mux4.0.sel0
net x100 hm2_7i92.0.7i77.0.0.input-27 => mux4.0.sel1
setp mux4.0.in0 .000001
setp mux4.0.in1 .00001
setp mux4.0.in2 .0001
net jogscale mux4.0.out => joint.0.jog-scale
net jogscale => joint.1.jog-scale
net jogscale => joint.2.jog-scale
net jogscale => joint.3.jog-scale
net mpg-out hm2_7i92.0.7i77.0.0.enc0.count => ilowpass.0.in
net jogcounts ilowpass.0.out => joint.0.jog-counts
net jogcounts => joint.1.jog-counts
net jogcounts => joint.2.jog-counts
net jogcounts => joint.3.jog-counts
net jogcounts => axis.x.jog-counts
net x-jog-select => axis.x.jog-enable
net jogscale => axis.x.jog-scale
net jogcounts => axis.y.jog-counts
net y-jog-select => axis.y.jog-enable
net jogscale => axis.y.jog-scale
net jogcounts => axis.z.jog-counts
net z-jog-select => axis.z.jog-enable
net jogscale => axis.z.jog-scale
net jogcounts => axis.a.jog-counts
net a-jog-select => axis.a.jog-enable
net jogscale => axis.a.jog-scale
#file name mpg.hal
loadrt mux4 count=1
loadrt ilowpass
The following user(s) said Thank You: tommylight, harindugamlath
22 Jun 2020 10:08 #172353
That was quick !
Thank you LC
Thank you LC
- harindugamlath
22 Jun 2020 10:16 #172355
by harindugamlath
Replied by harindugamlath on topic Probe basic jog wheel MPG help
Thanks guys for your kind support. I'm working on that hal file. But the issue is not having any hal pins from the probe basic itself. I couldn't find a good workaround. So I decided to go with physical input switches rather than trying to use hal pins from the gui.
If you guys can implement hal pins from the gui I suppose it can be incredibly useful.
- harindugamlath
22 Jun 2020 10:18 - 22 Jun 2020 10:19 #172357
by harindugamlath
Tommylight Thank you for helping out always. I'll start a detailed thread on my conversion hopefully it will be a help to someone.
Last edit: 22 Jun 2020 10:19 by harindugamlath.
22 Jun 2020 10:21 #172359
You are welcomed, always.
Sorry about the delay, but am busy finishing 2 plasma cutters, here:
forum.linuxcnc.org/show-your-stuff/38547...plasma-build?start=0
- harindugamlath
22 Jun 2020 11:05 #172365
by harindugamlath
- harindugamlath
22 Jun 2020 11:06 #172366
by harindugamlath
- harindugamlath
22 Jun 2020 11:06 #172367
by harindugamlath
Moderators: KCJ, Lcvette
