4th axis causing VTK backplot to fail
  • scotta
  • Platinum Member
  • Platinum Member
11 Jul 2020 23:21 #174340 by scotta
I've been using LinuxCNC for 3D printing for several years now and have been slowing building the ecosystem for the Raspberry Pi. My intent was to use QtOyVCP to develop a custom GUI. Just got VTK compiled and working and example GUI's work great. However when I import a ngc file with an A axis the backplot fails? Error points to the first line of G-code that has an A axis command.
Possible to fix? Axis works fine with more than just X, Y and Z..
Scott
  • scotta
  • Platinum Member
  • Platinum Member
18 Jul 2020 00:00 #174986 by scotta
Replied by scotta on topic 4th axis causing VTK backplot to fail
This is what happens when you use the Sim config and don't think... this was nothing to do with the back plot but the configuration not allowing an A axis.
When updated to use X Y Z A in the ini all worked as expected.
I hang my head in shame.
Scott
The following user(s) said Thank You: TurBoss, tommylight
18 Jul 2020 14:32 #175045 by tommylight
Replied by tommylight on topic 4th axis causing VTK backplot to fail
I read that when you posted it, but since i am not using any of those things, yet, i could not help.
Thanks for reporting back.
Moderators: KCJ, Lcvette
Time to create page: 0.306 seconds
