QtPyVcp - Edit Tool Table Bug
- TheBigLebowski
- Thank you received: 3
19 Aug 2020 17:44 #178730
by TheBigLebowski
QtPyVcp - Edit Tool Table Bug was created by TheBigLebowski
I have found a minor bug involving the tool table generated by qtpyvcp.
If you use the tool table editor located under file>Edit ToolTable (which appears to use Tooledit_dialog.ui), It contains all of the tooltable variables supported by linuxcnc, and by default saves all of them to the tool table file. This is a problem If you have a milling tool that contains any value for I J or Q in the tool table, it will cause an error when attempting to use cutter comp.
The following user(s) said Thank You: TurBoss
- TurBoss
- Thank you received: 81
19 Aug 2020 19:13 #178736
by TurBoss
Replied by TurBoss on topic QtPyVcp - Edit Tool Table Bug
Thank you for the report I'll take a look
- TurBoss
22 Aug 2020 20:57 - 22 Aug 2020 21:01 #179035
by TurBoss
Hello, Sorry for the delay
I found a solution,
the menu now shows a different dialog for mill and lathe based on the LATHE variable from the DISPLAY section of the INI
will be released soon
I found a solution,
Last edit: 22 Aug 2020 21:01 by TurBoss.
The following user(s) said Thank You: TheBigLebowski, hilo90mhz
Moderators: KCJ, Lcvette
Time to create page: 0.163 seconds
