[Error] - Requested Tool Not Found
- TurBoss
- Thank you received: 81
13 Sep 2020 16:42 - 13 Sep 2020 16:57 #182021
by TurBoss
Replied by TurBoss on topic [Error] - Requested Tool Not Found
>However as soon as i hit "save tool table" all the pockets are set to -1 and eventually the tool database gets cleared and overwritten again.
hello, this looks like a bug
edit:
>When i copy over the too table from the sim everything including touching off tools works
this looks like the problem
can you upload the sim tooltable
thanks
edit:
thanks
Last edit: 13 Sep 2020 16:57 by TurBoss. Reason: add details
- Thank you received: 7478
13 Sep 2020 17:36 #182025
Replied by tommylight on topic [Error] - Requested Tool Not Found
The tool number -1 has norhing to do with QtPyVCP or metric/imperial, it is most probably caused by power off of the PC and the resulting corruption in the files. That was my case.
Loop the tool change, change a tool, then revert back, that fixed it for me.
- sttts
12 Oct 2020 17:59 - 12 Oct 2020 18:00 #185862
by sttts
Replied by sttts on topic [Error] - Requested Tool Not Found
Make sure you have a custom_config.yml with column definitions in your machine dir, e.g.:
After this the table gets stored with pocket values and qtpyvcp works fine.
data_plugins:
tooltable:
provider: qtpyvcp.plugins.tool_table:ToolTable
kwargs:
columns: TPZDRAfter this the table gets stored with pocket values and qtpyvcp works fine.
Last edit: 12 Oct 2020 18:00 by sttts.
The following user(s) said Thank You: TurBoss
Moderators: KCJ, Lcvette
Time to create page: 0.175 seconds
