Probe basic setting new machine
- Mara2000
- Thank you received: 3
27 Aug 2020 20:36 #179737
by Mara2000
Probe basic setting new machine was created by Mara2000
just installed Probe basic ( quick install ) no development vrsion.
After installation, I see few sample configurations in the config folder, but only the sim versions. Does this mean that for a real machine I just have to edit the ini and hal configuration files in the ,,sim,, folder?
Thank you.
Thank you.
- KCJ
- Thank you received: 267
29 Aug 2020 00:59 #179896
by KCJ
Replied by KCJ on topic Probe basic setting new machine
If you have a working machine config already, all you need to do is change the [DISPLAY] DISPLAY option in your INI to probe_basic.
[DISPLAY]
DISPLAY = probe_basicPlease Log in or Create an account to join the conversation.
- Mara2000
29 Aug 2020 05:49 #179913
by Mara2000
Replied by Mara2000 on topic Probe basic setting new machine
Thank you, I thought it was necessary to adapt the sample halls and ini from probe basic due to the specific functions that are designed specifically for probe basic.
- KCJ
30 Aug 2020 02:22 #179999
by KCJ
If you don't have them in a standard location you will need to copy over the ProbeBasic specific sub routines, and you may need to tweak a few other things to your liking, but in general its best to start with a know working config and add what's needed for ProbeBasic, rather than try to adapt one of the probe basic sim configs.
- Mara2000
17 Sep 2020 19:36 - 17 Sep 2020 19:37 #182565
by Mara2000
after clean install Linux CNC 2.8 and Probe basic, when i start Probe basic sim then this error appear:
File "/home/cnc/.local/bin/probe_basic", line 11, in <module>
load_entry_point('probe-basic', 'gui_scripts', 'probe_basic')()
File "/home/cnc/qtpyvcp/pyqt5designer/Qt5.7.1-64bit/probe_basic/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/__init__.py", line 142, in run_vcp
launch_application(opts, config)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 78, in launch_application
loadWindows(config)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 211, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/vcp_launcher.py", line 205, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/home/cnc/qtpyvcp/pyqt5designer/Qt5.7.1-64bit/probe_basic/probe_basic/probe_basic.py", line 23, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 43, in __init__
self.loadUi(ui_file)
File "/home/cnc/.local/lib/python2.7/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 102, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/__init__.py", line 226, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/loader.py", line 72, in loadUi
return self.parse(filename, resource_suffix, basedir)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 1021, in parse
actor(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 118, in createQObject
return self._cpolicy.instantiate(factory, *args, **kwargs)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 137, in instantiate
return clsObject(*ctor_args)
File "/home/cnc/qtpyvcp/pyqt5designer/Qt5.7.1-64bit/probe_basic/widgets/atc_widget/atc.py", line 47, in __init__
self.pocket_slots = int(INIFILE.find("ATC", "POCKETS")) or 12
TypeError: int() argument must be a string or a number, not 'NoneType'
Thank you for help!
loadWindows(config)
actor(elem)
Thank you for help!
Last edit: 17 Sep 2020 19:37 by Mara2000.
- Mara2000
17 Sep 2020 20:38 #182573
by Mara2000
- TurBoss
- Thank you received: 81
18 Sep 2020 00:45 #182596
by TurBoss
Replied by TurBoss on topic Probe basic setting new machine
oops thats a bug
if you want to workarround it while i fix
add
to your ini
add
[ATC]
POCKETS=12Please Log in or Create an account to join the conversation.
- TurBoss
18 Sep 2020 00:47 #182597
by TurBoss
try
pip install --upgrade vtkPlease Log in or Create an account to join the conversation.
- Mara2000
18 Sep 2020 19:03 #182672
by Mara2000
just updated with:
...added to INI:
[ATC]
POCKETS=12
.... and still error apeared:
loadWindows(config)
actor(elem)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python2.7/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
ImportError: No module named dro_label
Thank you
just updated with:
...added to INI:
[ATC]
POCKETS=12
loadWindows(config)
actor(elem)
Thank you
- TurBoss
26 Sep 2020 19:35 #183873
by TurBoss
Hello,
did you ran the script located at "pyqt5designer/Qt5.7.1-64bit"
github.com/kcjengr/qtpyvcp/tree/master/p...signer/Qt5.7.1-64bit
Installing Designer Libs
These libraries have been tested to work in Debian 9 (stretch) Mint 19.1 and Ubuntu 18.04. They will likely work on other systems as well.
To install simply run:
sudo ./install.sh
sudo ./install.sh
The following user(s) said Thank You: Mara2000
Moderators: KCJ, Lcvette
Time to create page: 0.359 seconds
