qtpyvcp stored parameters
- anfänger
- Thank you received: 266
13 Sep 2020 14:11 - 13 Sep 2020 14:13 #182012
by anfänger
qtpyvcp stored parameters was created by anfänger
Hi,,
maybe this is stupid question again, but where can I din a list of stored parameters qtpyvcp ist using?
The reason is simple I want to know what tool was in the spindle before shutdown.
qtpyvcp ist restoring the the tool after homing. But I would like to know the tool number before homing.
And I think qtpyvcp is doing this with a parameter.
I have a m-code restoring the tools in atc after startup and I want to know if one of the tools is in the tool changer.
The reason for this is, I need to cool the bearings if my tool changer and want to set the signal while powering up.
I can manage already when changing tools, but not on startup.
Thanks Patrick
Thanks Patrick
Last edit: 13 Sep 2020 14:13 by anfänger.
- TurBoss
- Thank you received: 81
13 Sep 2020 15:49 - 13 Sep 2020 16:31 #182017
by TurBoss
Replied by TurBoss on topic qtpyvcp stored parameters
persistent data is stored with the "data_manager" plugin
read: github.com/kcjengr/qtpyvcp/blob/master/q...s/tool_table.py#L156
write: github.com/kcjengr/qtpyvcp/blob/master/q...s/tool_table.py#L205
kudos go to @KCJ
kudos go to @KCJ
Last edit: 13 Sep 2020 16:31 by TurBoss.
The following user(s) said Thank You: KCJ, anfänger
- anfänger
14 Sep 2020 05:40 #182053
by anfänger
Replied by anfänger on topic qtpyvcp stored parameters
Thanks,
can I access the „data_manager“ from M-Code?
Or otherwise fill the widget from python?
At the moment I am filling my atc widget this way:
And I want something like this (it‘s happening before homing, so qtpyvcp did not set the tool in spindle yet):
As an alternative to M135 I can manipulate a hal button
#1 = 0
o130 while [#1 LT 12]
#1 = [#1+1]
#2 = #[5189+#1]
(DEBUG, EVAL[vcp.getWidget{"dynatc"}.store_tool{#1, #2}])
o130 endwhileAnd I want something like this (it‘s happening before homing, so qtpyvcp did not set the tool in spindle yet):
#1 = 0
#1 = [#1+1]
#2 = #[5189+#1]
o135 if [#<tool_in_spindle]> eq #2]
M135 P1
o135 endif
o130 endwhileAs an alternative to M135 I can manipulate a hal button
Moderators: KCJ, Lcvette
Time to create page: 0.094 seconds
