Probe basic/mint 19
- Thods1222
01 Dec 2020 19:39 #190822
by Thods1222
Probe basic/mint 19 was created by Thods1222
I took the plunge on my newest retrofit and loaded up mint 19 and qtpyvcp. I really liked the look of probe basic and plan on using it. I did the install but have found that I cannot move the window into position. How do I get it into a usable place?
- KCJ
- Thank you received: 267
03 Dec 2020 08:23 #190964
by KCJ
Replied by KCJ on topic Probe basic/mint 19
If you press the F11 key the window will go out of full screen mode and you can drag it from the window borders. If you end up doing this often there is a INI option to make it start up not in full screen mode.
Cheers,
Kurt
Cheers,
Kurt
The following user(s) said Thank You: Thods1222
- Thods1222
03 Dec 2020 20:02 #191002
by Thods1222
Replied by Thods1222 on topic Probe basic/mint 19
Thank you that worked. Is there a size of screen that this is more friendly with? I have a 22" elo touch screen on the mill. The screen I was having troubles with is a 17" non touch screen.
- Lcvette
- Thank you received: 784
18 Jan 2021 08:38 #195802
by Lcvette
Probe Basic is only for 1920 x 1080 wide screen monitors. it was developed to utilize all the realestate available on a wide screen , i think there are some people working on alternate versions for non wide screen monitors.
Replied by Lcvette on topic Probe basic/mint 19
Moderators: KCJ, Lcvette
Time to create page: 0.087 seconds
