Porbe Basic Error On Startup
- Phazertwo
- Thank you received: 3
06 Dec 2020 01:37 #191210
by Phazertwo
Porbe Basic Error On Startup was created by Phazertwo
Hello everyone, I am new to Linuxcnc, and am a rookie at best when it comes to Linux. I have played with Mint some and enjoy running it on my spare computer... but that's about it. I am pretty well versed in step/dir CNC control having setup and run a Mach 3 machines and 2 machines using Centroid Acorn, Both Acorn machines included probing and tool height setting, one of which was a collet spindle, and the M6 macro actually measure the tool after you install it and then kicks back into the program.
After watching some youtubes about Prob Basic, I decided I had better give it a shot for my next project...
Anyway, I followed the installation instructions here: kcjengr.github.io/probe_basic/quick_start.html
I have Linux CNC up and running and talking to my 6I25 and 7I76. I have a very basic setup operating with Axis, however when I try to open Probe basic I get this error:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.1
Machine configuration directory is '/home/test/linuxcnc/configs/probe_basic/probe_basic'
Machine configuration file is 'probe_basic.ini'
INIFILE=/home/test/linuxcnc/configs/probe_basic/probe_basic/probe_basic.ini
VERSION=1.1
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z A B
KINEMATICS=trivkins coordinates=XYZAB
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./hallib/core_sim_5.hal
twopass:found ./hallib/spindle_sim.hal
twopass:found ./hallib/simulated_home_probe_basic.hal
twopass:found ./hallib/sim_cannon.hal
Starting DISPLAY program: probe_basic
task: 268 cycles, min=0.000065, max=0.010212, avg=0.008958, 0 latency excursions (> 10x expected cycle time of 0.010000s)
I have tried uninstalling and reinstalling both prob basic and Linuxcnc to make sure that I didn't miss anything, but I get the exact same results...
I am wondering if it has to do with the fact that I setup using Pcconf and Axis. Do I need to point probe basic to the config files? I don't see anywhere to do that, and the Prob Basic sim gives me the same issue...
Thanks for any help!
PZ
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.1
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
PZ
- Phazertwo
10 Dec 2020 14:12 #191601
by Phazertwo
Replied by Phazertwo on topic Porbe Basic Error On Startup
Almost 90 views and no suggestions? Is there a better place for this post?
I get the feeling what ever I am missing is staring me right in the face and it's a very simple noob thing to miss...
PZ
PZ
- Thank you received: 7504
10 Dec 2020 14:19 #191602
Replied by tommylight on topic Porbe Basic Error On Startup
Blame it on this pandemics !
There are some sim_xxxx.hal files still called from your ini file, those will have to be removed for use on an actual machine.
- Phazertwo
10 Dec 2020 15:49 #191609
by Phazertwo
I just tried to uninstall, and re install Linuxcnc with. Then I tried to install Probbasic with out making a PNCconf for my test setup... Looks like I got a debug error this time (maybe I had it last time and just didn't copy it when I posted the error??). See attached file for the whole retort, but it looks like my OpenGL drivers are not up to date... A few minutes searching and I cannot find anything about upgrading the OpenGL drivers... or is it that my device cannot support it?
debug file information:
Note: Using POSIX realtime
motion.c: Creating unlock hal pins for joint 4
ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 797
vtkXOpenGLRenderWindow (0x55fbd91e8f90): GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend. Please update your OpenGL driver. If you are using Mesa please make sure you have version 10.6.5 or later and make sure your driver in Mesa supports OpenGL 3.2.
Again any help would be much appreciated.
PZ
PZ
10 Dec 2020 16:09 #191613
What version of Linux are you using ?
It most probably means the graphic card does not support OpenGL.ERROR: In /work/standalone-x64-build/VTK-source/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 797
- Phazertwo
10 Dec 2020 21:52 #191639
by Phazertwo
LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT ISO
Downloaded from here:
www.linuxcnc.org/downloads/
I think I have a video card somewhere that I can throw in it. I will give that a shot in the next few days and report back.
PZ
PZ
- Phazertwo
28 Dec 2020 15:24 #193380
by Phazertwo
Just to close this out, it was the video card. I added a cheapo I had laying around and it worked with the next boot, no other changes were made.
Probe basic seems to be run just fine, I have run probably 5hrs worth of programs on my test setup with out seeing any issues. Looking forward to moving over to a real machine to test.
Thanks for the help!
PZ
PZ
The following user(s) said Thank You: TurBoss, tommylight
28 Dec 2020 16:42 #193383
Thanks fro reporting back.
Moderators: KCJ, Lcvette
Time to create page: 0.093 seconds
