Probe Basic Screen Problem
- jc2ktr
- Thank you received: 17
01 Jan 2021 04:38 #193715
by jc2ktr
Probe Basic Screen Problem was created by jc2ktr
First a Happy new Year to all
I wanted to use the Probe Basic Screen for my LinuxCNC Machine,
i am able to run the Screen with my Hal/InI Configuration but it is not Possible to enable the Machine.
The signal/pin for iocontrol.0.user-enable-out seems not to Work, when i use the machine with the simulated hardware it is functioning.
On which states depends this signal?
greetings Sven
greetings Sven
- Thank you received: 7504
21 Jan 2021 11:04 #196105
Replied by tommylight on topic Probe Basic Screen Problem
Is it possible to get the machine out of e-stop ?
Posting your config files might help.
- jc2ktr
23 Jan 2021 03:57 #196319
by jc2ktr
When i use the gmoccapy screen i am able to reset and activate the machine.
My e-stop is created with a classicladder plc in both screensets.
But in the probe basic it seems not to work correctly.
I`ve added a tar.gz with my config.
Replied by jc2ktr on topic Probe Basic Screen Problem
Moderators: KCJ, Lcvette
Time to create page: 0.155 seconds
