Probe Basic auf Himbeere 4 Modell B
  • thomas.heisig
  • thomas.heisig's Avatar Topic Author
  • New Member
  • New Member
04 Jan 2021 14:02 - 04 Jan 2021 14:05 #194068 by thomas.heisig
Probe Basic auf Himbeere 4 Modell B was created by thomas.heisig
Hallo (Halo),
I´m new in this forum, and, also new in Linux.
My last CNC system Previously was a 3 Axis Saw on UCCNC and UC300ETH and it worked fine but there is no room for things like Realtime Encoders or Ethercat so I try LinuxCNC.
And then it starts with ….. Problems!
It seems not possible (for me) to install Probe Basic on the RAS 4B
I´ve try the instructions from probe-basic · PyPI
everything is fine until the Installation from ProbeBasic-Installer-0.2.9.run.
when I try to, nothing happens, when I try to run over the Terminal the error is ELV: not found
Greetings from Germany
Thomas
My Configuration:
Raspberry Pi 4 B 4 GB Linux CNC 2.8.1 on SD Card Debian Buster Image for PI
MESA Electronics 7i95 6-Axis Ethernet Card (delivery tomorrow)
Machine – 6 Axis Servo (5+1) 3000 * 2000 mm Retrofit
Last edit: 04 Jan 2021 14:05 by thomas.heisig.
05 Jan 2021 03:39 #194131 by anfänger
Replied by anfänger on topic Probe Basic auf Himbeere 4 Modell B
Hi try the development install:
kcjengr.github.io/probe_basic/dev_install.html
Did this last weekend Worked for me without any problems.
  • thomas.heisig
  • New Member
  • New Member
06 Jan 2021 09:16 #194234 by thomas.heisig
Replied by thomas.heisig on topic Probe Basic auf Himbeere 4 Modell B
hello together,
this time I tried to install Linuxcnc 2.9.0 on Debian Buster RT directly,
and then VTK; Python... via the Synaptic, which also completed without any errors.
The "Probe Basic" still does not start an installation, but only leaves a file without a name in the download directory.
at this time i think i must take a gun and shot the Pi right betwhen his ARM CPU and buy a Big x86 Mainboard.
Greetings Thomas
06 Jan 2021 10:44 #194248 by tommylight
Replied by tommylight on topic Probe Basic auf Himbeere 4 Modell B
LOL, i did that long ago, never looked back. :)
Moderators: KCJ, Lcvette
