How to add picture graphic image to gui qtpyvcp
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
15 Jan 2021 00:02 - 20 Jan 2021 12:08 #195404 by aleksamc
I want to add some help picture to gui linuxcnc in pyqtvcp.
I add it to recources file. Inside resources file I have
<RCC>
  <qresource lang="all" prefix="images">
    <file>help_stone.png</file>
  </qresource>
</RCC>
I tried 2 methods with Label:
1) In QSS stylesheet:
image: url(":/images/help_stone.png");
2) Rigth bottom press on label > Change rich text > chouse picture
Both ways picture adds to QT Designer and it seen. But When I run linuxcnc, place where picture should be is blank.
What I do wrong? I see other configurations has picture and they are even can rotate (for example tool change), but I'm stuck on so basic problem:side:
Last edit: 20 Jan 2021 12:08 by aleksamc.
  • aleksamc
  • Platinum Member
  • Platinum Member
21 Jan 2021 13:23 #196129 by aleksamc
It's realy nobody knows what problem is?
I saw a lot of QtPyVCP guis and they had graphic, I don't know what I'm doing wrong.
21 Jan 2021 14:20 - 21 Jan 2021 14:22 #196143 by Lcvette
adding graphics requires the graphics to be in a directory specified for images with the correct path, you also need to add the image file path to the .qrc file, then you need to compile.
Last edit: 21 Jan 2021 14:22 by Lcvette.
  • aleksamc
  • Platinum Member
  • Platinum Member
24 Jan 2021 12:03 - 24 Jan 2021 12:05 #196439 by aleksamc
Unfortunatly doesn't work:
I wrote in terminal:
qcompile stonecnc
Compiling .ui files in package 'stonecnc':
mainwindow.ui => mainwindow_ui.py ... ok
Compiling .qrc files in package 'stonecnc':
resources.qrc => resources_rc.py ... ok
My file qrc
File Name: resources.qrc.txt
File Size:0 KB
But when I run linuxcnc I don't see any picture. Could be problem with Language settings?
Last edit: 24 Jan 2021 12:05 by aleksamc.
The following user(s) said Thank You: Lcvette
25 Jan 2021 22:44 #196603 by Lcvette
qcompile stonecnc
My file qrc
File Size:0 KB
hmmm, not sure it should be working, how are you inserting the image into the ui?
  • aleksamc
  • Platinum Member
  • Platinum Member
02 Feb 2021 15:41 #197479 by aleksamc
I use QLabel, then I change it's QSS an there I add image: url(":/images/help_stone.png".
I explained it in the 1-st topic.
02 Feb 2021 20:53 #197519 by Lcvette
you need to place the label where you want it, then select it and in the property editor under QLabel/test/pixmap there is a drop down manu, select "choose resource" then in the new window that opens click on images, then select your image and click OK should be there, then you shouod run . qcompile and check your ui it should be there!
  • aleksamc
  • Platinum Member
  • Platinum Member
03 Feb 2021 04:06 #197533 by aleksamc
I think you will not believe me, but I did everything as you said. And I see image in qtdevelopper, and compilling finished witout errors. But linuxcnc still opens with blank image.
03 Feb 2021 08:53 #197553 by Lcvette
I just tested and it is working, im not sure why yours is not? what version of qtpyvcp do you have installed?
  • aleksamc
  • Platinum Member
  • Platinum Member
04 Feb 2021 23:47 #197706 by aleksamc
In Qt Designer is evrything fine, I see picture well.
But in Linuxcnc it's blank.
So linuxcnc is 2.8.1 version
and QtDesigner version is 5.11.3 as same as Qt.
All plugins are run except libpyqt5_py3.so
Could you add here some of yours picture that I could try to add and to see if problem is not in file?
Moderators: KCJ, Lcvette
Time to create page: 0.229 seconds
