How to get values from retain memory and ini file?
- aleksamc
- Thank you received: 67
24 Feb 2021 15:39 #200039
by aleksamc
How to get values from retain memory and ini file? was created by aleksamc
I wan't to get from ini file value of maximum speed for setting jog speed . As in the
basic tutorial
Also QHSpinbox I would like to save last value to some file that in next turn on, it will load values from that file.
Does it's possible to do this?
- HansU
- Thank you received: 217
13 Mar 2021 05:07 #202083
by HansU
Replied by HansU on topic How to get values from retain memory and ini file?
For saving persistent values have a look at github.com/LinuxCNC/linuxcnc/blob/b8ce6c.../persistence.py#L122
And for reading the INI file could this be useful I think: github.com/LinuxCNC/linuxcnc/blob/b8ce6c...y/getiniinfo.py#L242
In forum.linuxcnc.org/gmoccapy/40709-gmocap...lock?start=30#201950 you find an example how to use this.
The following user(s) said Thank You: aleksamc
- aleksamc
13 Mar 2021 13:11 #202128
by aleksamc
Replied by aleksamc on topic How to get values from retain memory and ini file?
Thanks Hansu for your answer. Please give me more information where I can connect this python code? I've never used gmoccapy.
- HansU
13 Mar 2021 13:25 - 14 Mar 2021 04:06 #202132
by HansU
It is not only for gmoccapy. What GUI do you use?
Hans
Hans
Last edit: 14 Mar 2021 04:06 by HansU.
- aleksamc
13 Mar 2021 13:29 #202133
by aleksamc
I use QtPyVCP, there is main file .py where I add functions for buttons.
- HansU
14 Mar 2021 04:09 - 14 Mar 2021 16:00 #202199
by HansU
Ok what stupid question of me as your post is in the QtPyVCP sub forum
So you just have to import the libs like
and create a IniFile object and so on...
from gladevcp.persistence import IniFile # we use this one to save the states of the widgets on shut down and restart
Last edit: 14 Mar 2021 16:00 by HansU.
- aleksamc
14 Mar 2021 11:14 #202224
by aleksamc
Ok, thanks, I will try.
I'm not so good in python but I will try.
- aleksamc
13 May 2021 10:35 - 13 May 2021 10:58 #208738
by aleksamc
I copied to directory with main file.py
persistance.py and getiniinfo.py.
in main file i added
And also lineBut I really doesn't understand from what directory file is imported.
and visualisation doesn't load.
But really I don't know logic of execution of QtPyVCP, I write to this file functions that should be executable when buttons pressed,
import persistance.py
import getiniinfo.pyAnd also line
from gladevcp.persistence import IniFileand visualisation doesn't load.
Last edit: 13 May 2021 10:58 by aleksamc.
- HansU
16 Jan 2022 02:45 #231991
by HansU
Basically you have to do something like this
import linuxcnc
inifile = linuxcnc.ini("name amd path of ini file")
max_jog_vel = inifile.find("TRAJ","MAX_LINEAR_VELOCITY")Please Log in or Create an account to join the conversation.
Moderators: KCJ, Lcvette
Time to create page: 0.198 seconds
