probe_basic errore 0x559889a050f0
- Dadoblu_2000
23 Mar 2021 13:30 - 23 Mar 2021 13:33 #203389
by Dadoblu_2000
probe_basic errore 0x559889a050f0 was created by Dadoblu_2000
Hi, I made a clean installation of linuxcnc debian10 linuxcnc 2.8.1 then I ran the guides to install the video interface of probe_basic, but something doesn't work, as soon as I launch the probe-basic program it should start, I visualize the interface for a second and then it closes with the following error.
Last edit: 23 Mar 2021 13:33 by Dadoblu_2000.
- Thank you received: 5331
23 Mar 2021 14:32 #203394
Probably means that your video hardware is too old to support GL 2.1
(Core Duo vintage Intel graphics has this issue)
Replied by PCW on topic probe_basic errore 0x559889a050f0
GL version 2.1 with the gpu_shader4 extension is not supported by your graphics driver but is required for the new OpenGL rendering backend.
- Dadoblu_2000
23 Mar 2021 17:55 #203411
by Dadoblu_2000
Replied by Dadoblu_2000 on topic probe_basic errore 0x559889a050f0
is it just a hardware problem or driver updates? so if i add a video card i could solve the problem
23 Mar 2021 18:04 #203413
Its solvable by using a add-on video card
Whether its a hardware of software problem is rather subtle
(its probably possible to make a updated GL driver for the older
video hardware but no-one has bothered)
- Dadoblu_2000
24 Mar 2021 07:34 #203489
by Dadoblu_2000
01.org/linuxgraphics/downloads
I found this internet page dedicated to intel drivers for linux, but honestly I have no idea how to install the drivers, I don't know all the commands to do it, do you have any idea if it is possible?
- OpenDev
06 Apr 2021 14:34 - 06 Apr 2021 14:37 #205121
by OpenDev
Replied by OpenDev on topic probe_basic errore 0x559889a050f0
Hello, had the same Problem. The internal grafic card has the newest opengl support, but there is no implementation in the linux driver... or it is to old. just use a extra grafic card. you can test probe basic if you use the software rendering. But is not usable for work
you can test it. Start linuxcnc with LIBGL_ALWAYS_SOFTWARE=1
Last edit: 06 Apr 2021 14:37 by OpenDev.
Moderators: KCJ, Lcvette
Time to create page: 0.101 seconds
