help installing on RPI 4
- Aaroncnc
- Thank you received: 45
02 Apr 2021 17:46 - 02 Apr 2021 23:23 #204538
by Aaroncnc
help installing on RPI 4 was created by Aaroncnc
Hello,
I have tried reading other threads and have gotten a bit of info and solved a few road blocks but i cant seem to get it working.
To start.
I downloaded the RPI image www.linuxcnc.org/iso/linuxcnc-2.8.1-pi4.zip
I then ran an axis sim to confirm it works and i have a config directory
I then cloned github.com/kcjengr/qtpyvcp into a folder called "qt from source from git"
I then edited setup.py to comment out VTK
I then downloaded and installed github.com/scottalford75/LinuxCNC-on-RPi...1-qt5py2-1_armhf.deb
Then i modified my .bash.hrc file withthen ranRestarted system
then ran
Then from inside the source directory for Qt i ran "pip install --editable ."
I then copied the configs from the source into linux cnc config.
I can run the QtPyVCP test no problem.
But if i select any other option i get the error "No module named VTK"
I am using this guide as my source for my steps
scottalford75.github.io/LinuxCNC-on-RPi/...20for%20QtPyVCP.html
I feel i may have missed something obvious but i cant find where.
Edit
If i runI get
If i runI get no errors
Edit 2
I found that i somehow had pypy2.7 running so i removed it and restarted my system
not sure removing that solved it...
Seems when i run linux cnc from cmd line is the difference.
Now i can get the VTK test to run.
But the open GL test fails with the following
Still stuck
To start.
export PYTHONPATH=/usr/local/lib/python2.7/site-packages:/usr/local/lib/python2.7/site-packages/vtk:$PYTHONPATH
export LD_LIBRARY_PATH=/usr/local/lib:/usr/local/lib/python2.7/site-packages/vtk:$LD_LIBRARY_PATHsudo apt-get install -y notification-daemonthen ran
sudo apt-get install libhdf5-dev libnetcdf-cxx-legacy-dev libjsoncpp-dev libgl2ps-devThen from inside the source directory for Qt i ran "pip install --editable ."
Edit
If i run
sudo dpkg --list | grep vtklibvtk6.3 6.3.0+dfsg2-2+b6
vtk 7.1.1_qt5py2-1If i run
"$ python
>>> import PyQt5"Edit 2
pi@linuxcnc:~ $ linuxcnc
LINUXCNC - 2.8.1
Machine configuration directory is '/home/pi/linuxcnc/configs/qtdragon'
Machine configuration file is 'xyz-metric.ini'
Starting LinuxCNC...
File: tool.tbl Unrecognized line skipped: ;Tool Pocket X Offset Y Offset Z Offset Diameter Remark
Found file(REL): ./hallib/core_sim_3.hal
Note: Using POSIX realtime
Found file(REL): ./hallib/spindle_sim.hal
Found file(REL): ./hallib/simulated_home.hal
qt5ct: using qt5ct plugin
[qtpyvcp.lib.decorators][WARNING] Deprecation Warning: The widget "qtpyvcp.widgets.display_widgets.dro_widget.DROWidget" has been deprecated and will be removed in the future. Reason: new DRO implementation. Replaced by: DroLabel. (decorators.py:25)
qt5ct: D-Bus global menu: no
[qtpyvcp.app.launcher][CRITICAL] Unhandled exception in qbackplot.py line 490 (launcher.py:38)
File "/home/pi/qt source from git/qtpyvcp/qtpyvcp/widgets/display_widgets/gcode_backplot/qbackplot.py", line 490, in initializeGL
self.realize()
File "/home/pi/qt source from git/qtpyvcp/qtpyvcp/widgets/display_widgets/gcode_backplot/qbackplot.py", line 327, in realize
glcanon.GlCanonDraw.realize(self)
File "/home/pi/qt source from git/qtpyvcp/qtpyvcp/widgets/display_widgets/gcode_backplot/glcanon.py", line 459, in realize
self.hershey = hershey.Hershey()
File "/usr/lib/python2.7/dist-packages/hershey.py", line 115, in __init__
glEnd()
error: (1282, 'invalid operation')
Still stuck
Last edit: 02 Apr 2021 23:23 by Aaroncnc.
- scotta
- Thank you received: 489
03 Apr 2021 20:40 #204663
by scotta
Replied by scotta on topic help installing on RPI 4
I don't think the OpenGL back plot will work on the Pi. Hence the reason for the VTK version.
- Aaroncnc
03 Apr 2021 21:30 #204672
by Aaroncnc
Replied by Aaroncnc on topic help installing on RPI 4
So is it possible to use the included configs?
I select the Brender example and i get the same crash as the open gl test.
Also if u run linux cnc from the desktop shortcut i get the error VTK not found but if i run it from terminal its fine.
- Aaroncnc
04 Apr 2021 20:51 #204811
by Aaroncnc
So i installed probe basic. (note the QtPyVCP doc said it is preinstalled but it was not or i misunderstood
Project URL: Included with QtPyVCP
It seems to run great and looks awesome, BUT the ATC screen is blank and i am getting some messages in terminal.
Also still cant seem to figure out why If i run linux cnc via desktop shortcut i get VTK not found error but if i run it via console it works fine.
LINUXCNC - 2.8.1
Machine configuration directory is '/home/pi/linuxcnc/configs/probe_basic'
Machine configuration file is 'probe_basic.ini'
File: tool.tbl Unrecognized line skipped: ;Tool Pocket Z Offset Diameter Remark
twopass:invoked with <> options
twopass:found ./hallib/core_sim_5.hal
twopass:found ./hallib/spindle_sim.hal
twopass:found ./hallib/simulated_home_probe_basic.hal
twopass:found ./hallib/sim_cannon.hal
motion.c: Creating unlock hal pins for joint 4
qt5ct: D-Bus system tray: no
QEGLPlatformContext: Failed to make temporary surface current, format not updated (3002)
qt5ct: custom style sheet is disabled
QEGLPlatformContext: eglMakeCurrent failed: 3002
QQuickWidget: Failed to make context current
QQuickWidget::resizeEvent() no OpenGL context
QQuickWidget: Attempted to render scene with no context
composeAndFlush: makeCurrent() failed
composeAndFlush: makeCurrent() failedAlso still cant seem to figure out why If i run linux cnc via desktop shortcut i get VTK not found error but if i run it via console it works fine.
- Aaroncnc
05 Apr 2021 13:59 #204902
by Aaroncnc
I found out why i could only get linux cnc to work via terminal and not any shortcuts or launchers.
I had to modify ".profile" the same way i did ".bashrc"
Still stuck on the ATC screen being blank as in my above comment.
Moderators: KCJ, Lcvette
Time to create page: 0.552 seconds
