- User Interfaces
- Other User Interfaces
- QtPyVCP
- after probe-basic dev upgr: tkAxisActor Number of labels -2147483647 is invalid
- freisei
18 Apr 2021 10:37 - 18 Apr 2021 10:43 #206291
by freisei
after probe-basic dev upgr: tkAxisActor Number of labels -2147483647 is invalid was created by freisei
Hi @ll,
i tried to update my probe-basic copy to the latest from repos, now i get this error and can´t find any entry point to get rid of this.
upgrade was done by following commands: (i could not find any official doc for upgrade a probe basic dev install)
if relevant:updated linuxcnc to the latest 2.9.0pre from source and updated everything via apt - no changes
Any Ideas?
Nice greets from Bavaria
Freisei
[qtpyvcp][INFO] Loading global stylesheet: /usr/local/src/probe_basic/probe_basic/probe_basic.qss (application.py:186)
Clear and load history to list
[qtpyvcp.app.launcher][INFO] Loading POSTGUI_HALFILE: /home/freisei/linuxcnc/configs/martha/postgui_call_list.hal (launcher.py:96)
ERROR: In /work/standalone-x64-build/VTK-source/Rendering/Annotation/vtkAxisActor.cxx, line 1872
vtkAxisActor (0x55f94b5ae920): Number of labels -2147483647 is invalid
vtkAxisActor (0x55f94b6d2720): Number of labels -2147483647 is invalid
vtkAxisActor (0x55f94b7f7ed0): Number of labels -2147483647 is invalid
vtkAxisActor (0x55f94b91d4c0): Number of labels -2147483647 is invalid
task: main loop took 0.195366 seconds
task: main loop took 0.404114 seconds
ERROR: In /work/standalone-x64-build/VTK-source/Common/Core/vtkGenericDataArray.txx, line 443
vtkFloatArray (0x55f94b60e4b0): Unable to allocate 6442450941 elements of size 4 bytes.
cd /usr/local/src/qtpyvcp
git pull
pip install --editable .
cd /usr/local/src/probe_basic/
git pull
qcompile .
pip install -e .if relevant:
root@linuxcnc:~# dpkg -l |grep vtk
ii libvtk6.3 6.3.0+dfsg2-2+b5 amd64 VTK librariesAny Ideas?
Freisei
Last edit: 18 Apr 2021 10:43 by freisei. Reason: additional system infos
- Lcvette
- Thank you received: 782
18 Apr 2021 12:44 #206303
by Lcvette
Replied by Lcvette on topic after probe-basic dev upgr: tkAxisActor Number of labels -2147483647 is invalid
did you also update qtpyvcp?
- freisei
18 Apr 2021 14:13 #206306
by freisei
Replied by freisei on topic after probe-basic dev upgr: tkAxisActor Number of labels -2147483647 is invalid
yes, i think. As written in Post.
cd /usr/local/src/qtpyvcp git pull pip install --editable .
- freisei
18 Apr 2021 14:16 #206307
by freisei
btw: the default probe_basic config is running fine. So i think its not a software/version issue.
- freisei
18 Apr 2021 14:49 #206308
by freisei
solved by
freisei@linuxcnc:~/linuxcnc/configs/martha$ rm rs274ngc.var
freisei@linuxcnc:~/linuxcnc/configs/martha$ rm rs274ngc.var.bak
But: i dont know exactly why.
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 1.447 seconds
