Problem in few probing in one time.
- aleksamc
- Thank you received: 67
18 May 2021 11:31 #209341
by aleksamc
Problem in few probing in one time. was created by aleksamc
I remaped M-program for probbing.
I use G38.4 for probe - Move up to lose contact with probe.
When I run probe first time, it works fine, but when I try secon time. I get error in qtPyVCP visual:
What does it mean? Possibly I need to reset some parameters as I understood.
Probe is already clear when starting G38.4 or G38.5 mode
19 May 2021 12:44 #209499
Replied by andypugh on topic Problem in few probing in one time.
To probe from motion.probe-in = true to motion.probe-in = false it is necessary that the state is true at the start of the probe move. The error message indicates that this is not the case.
- aleksamc
20 May 2021 07:57 #209622
by aleksamc
Replied by aleksamc on topic Problem in few probing in one time.
I used G38.4 to probe that is mean:
I tried to to disconnect sensor but when I start probing I must connect prob to tool.
Tool is Saw with 200mm diameter for stone cutting.
I use G10L20 code if probbing is succesfull, may be I need to use something else.
Current I use inductive sensor and manualy touch the tool. And move up from tool. So, conditionG38.4 - probe away from workpiece, stop on loss of contact, signal error if failure
is fulfield in some kind.To probe from motion.probe-in = true to motion.probe-in = false it is necessary that the state is true at the start of the probe move.
21 May 2021 08:14 #209741
Maybe there is noise on the probe sensor input? You could try debouncing it slightly.
- aleksamc
21 May 2021 19:44 #209788
by aleksamc
So, I found where problem is.
In code G38.4 I need to set current position for Z + [some shift], coordinate was in absolute coorinates.
So, now everything works fine.
Moderators: KCJ, Lcvette
Time to create page: 0.245 seconds
