Manual tool chang in probe basic
03 Jun 2021 04:14 #211053 by mhd325ic
Manual tool chang in probe basic was created by mhd325ic
I am new to probe basic, please forgive me if I am asking naive questions. My milling machine, which doesn't have a ATC, is controlled by linuxcnc with a probe basic gui. Everything works well, but it won't prompt to change tool. It seems the default behaviour of probe basic is ATC.
How can I configure the probe basic to prompt a manual tool change?
The following user(s) said Thank You: Lcvette
03 Jun 2021 08:25 #211078 by harindugamlath
Replied by harindugamlath on topic Manual tool chang in probe basic
Usually probe basic gives the pop up dialog to confirm the tool change. for some reason your ini and hal might have something different. I remember having few lines on tool change. need to have a look on the machine.
I can attach my files if you need. its from my working mill. same as yours without atc.
03 Jun 2021 11:26 - 03 Jun 2021 12:15 #211087 by mhd325ic
Replied by mhd325ic on topic Manual tool chang in probe basic
Thanks for offering your configuration. I have been googling an working example setup for linuxcnc and got confused results: some example says a m6 remap will do the trick and the others add iocontrol and hal. It would be a great help to see an example setup in probe_basic.
Last edit: 03 Jun 2021 12:15 by mhd325ic.
04 Jun 2021 23:06 - 04 Jun 2021 23:08 #211180 by BigJohnT
Replied by BigJohnT on topic Manual tool chang in probe basic
Manual tool change is an hal entry in your main hal file.
# manual tool change
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
If you have conflicts in pb you would have to resolve them.
JT
Last edit: 04 Jun 2021 23:08 by BigJohnT.
The following user(s) said Thank You: Lcvette, mhd325ic
05 Jun 2021 09:03 #211203 by harindugamlath
BigJohnT has replied you with the proper hal.
here is my hal file if you need to have a look
07 Jun 2021 15:42 #211425 by mhd325ic
Thank BigJohnT and Harindugamlath! It works if I comment the line of "net tool-prepare-loopback iocontrol.0.tool-prepare => hal_manualtoolchange.tool-prepared". It seems it defined somewhere in probe_basic.
The tool length compensation seems works with presetted value in tooltable. Finally I am ready to make the first CNC milling run!
Appreciated helps from everybody!
The following user(s) said Thank You: harindugamlath
24 Oct 2023 16:03 - 24 Oct 2023 16:07 #283715 by udoS
Replied by udoS on topic Manual tool chang in probe basic
Hi to all,
I'm using Probe-Basic;
@BigJohnT
How do I set my ToolChange Position ?
If I make a ToolChange like M6 T2 then my Z-axis allways first go to Z0, then ask to make the toolchange !
Best Regards
Last edit: 24 Oct 2023 16:07 by udoS.
24 Oct 2023 17:29 #283732 by Lcvette
Replied by Lcvette on topic Manual tool chang in probe basic
are you using the tool setter function or just want to set a tool change position?
the tool setter position is on the offsets page I just made a video showing how to set that, for standard M6 tool change position coordinates, that is set in the ini per the documents for linuxcnc.
linuxcnc.org/docs/2.9/html/config/ini-co...ml#sub:ini:sec:emcio
Moderators: KCJ, Lcvette
Time to create page: 0.206 seconds
