Access Mesa Pins from QTPYVCP
- christianr
13 Jun 2021 09:49 #211942
by christianr
Access Mesa Pins from QTPYVCP was created by christianr
Hello,
i have installed QTPYVCP on my Machine and played a bit with it. Its very nice and works fine. Then i found, that i can add Buttons and other GUI Elements very easy to the GUI. But there is my Question:
How can i connect the Button to a In or Outputpin of my Mesa 7i76e ? I want to enable my vacuumpump via Relais.
It would be very nuce, if somebody can help me.
Thank you!
Have a nice day.
Thank you!
Have a nice day.
- BigJohnT
- Thank you received: 994
13 Jun 2021 11:37 - 13 Jun 2021 11:40 #211950
by BigJohnT
Replied by BigJohnT on topic Access Mesa Pins from QTPYVCP
You can use an Action Button to turn on and off Coolant. In your hal file just make the connection from coolant to the output on the 7i76e.
www.qtpyvcp.com/components/action_buttons.html
The hal line would be something like this, I'm looking at my 5i25/7i77 machine so the output syntax might be off a bit.
JT
net coolant iocontrol.0.coolant-flood hm2_7i76e.0.0.output-00JT
Last edit: 13 Jun 2021 11:40 by BigJohnT.
- christianr
13 Jun 2021 11:45 #211951
by christianr
Replied by christianr on topic Access Mesa Pins from QTPYVCP
Okay thx. I tried it with qtpyvcp.MYBUTTONNAME... but qtpyvcp was not found...
I will try it with iocontrol. Thank you.
- christianr
13 Jun 2021 14:35 #211963
by christianr
I was just at the machine and tried it. However, my ActionButton is not displayed in the HAL. Do I need to make any other settings in QTDesigner? I had added a normal button the last few days and it was displayed in the HAL.
- BigJohnT
13 Jun 2021 14:50 #211964
by BigJohnT
Once you setup the Action Button for Coolant then you connect the iocontrol.0.coolant-flood to your output pin. Also note you probably want to use coolant toggle and change the background color when it's on.
JT
JT
- christianr
13 Jun 2021 15:19 #211969
by christianr
But I don't want to use that for cooling but for a vacuum table and other things. What would I then enter instead of: iocontrol.0.coolant-flood ?Can I only take predefined? Like here in the case collant-flood ? Where do I write my button name or something like that ?
- Joco
- Thank you received: 327
14 Jun 2021 00:56 - 14 Jun 2021 01:21 #211999
by Joco
Replied by Joco on topic Access Mesa Pins from QTPYVCP
Apologese if I am missing the point but if you want to adjust the gui and use a button or other gui control to activate a HAL pin that you are using to control a relay or some such to activate your vacum pump (or antything else for that matter) then you can look at:
www.qtpyvcp.com/widgets/hal/index.html
However if you want to activate and deactivate via gcode you need to look at the M62 to M65 gcodes. These trigger on/off bits on the motion.digital-out-xx (where xx is a number per documentation).
Edit 1: Equally if your machine has no coolant function there is nothing wrong with using the existing coolant pins. However if you do have coolant as a capability as well as the vac system then see above for ideas.
Edit 2: If you want to change the button name for an existing coolant button then you will either need to open the .ui file in qtdesigner and adjust the button text or open the .ui file in a text editor, search for the existing button txt and change it. Depending on the gui there may be a need to run the qcompile command (www.qtpyvcp.com/tools/qcompile.html).
Cheers - J.
Cheers - J.
Last edit: 14 Jun 2021 01:21 by Joco.
The following user(s) said Thank You: christianr
- BigJohnT
14 Jun 2021 11:08 #212035
by BigJohnT
Thanks to Joco for reminding me of the Hal Buttons. Simply add a hal button and give it the name you want to use in hal and in your postgui hal file make the connection from the button to the output of your choice. If you want the button to be a toggle button simply enable the checkable item in the property editor.
JT
JT
- christianr
15 Jun 2021 00:10 #212096
by christianr
Thank you very much. That was the Clue. Iam using HALButtons right now. And now i works.
Moderators: KCJ, Lcvette
Time to create page: 0.133 seconds
