Probe Basic mx velocity for XHC- WHB04
- FedX
05 Jul 2021 04:53 #213753
by FedX
Probe Basic mx velocity for XHC- WHB04 was created by FedX
Hi all,
can annyone tell me where i can find the Hal pin for the jog velocity slider ?
Whenever i jog with the handwheel it is running with 100% velocity, which is far to much for only 0.1mm steps.. I have connected whb.halui.max-velocity.value to halui.max-velocity.value but thats not working.
I checked all Hal Pins i could find, but none of those had the value from the slider.
best regards
best regards
- Thank you received: 4659
05 Jul 2021 17:36 #213799
Replied by andypugh on topic Probe Basic mx velocity for XHC- WHB04
I think that it might depend on the UI that you are using. And it is also likely that not all of them respond to an external change.
(I would expect the change in halui to work, but I would not necessarily expect the GUI to show the change)
- FedX
06 Jul 2021 01:59 #213829
by FedX
Replied by FedX on topic Probe Basic mx velocity for XHC- WHB04
you got me wrong, I don't want to see any change of feedrate in my UI. I want that the max feedrate override slider in % also takes effect while jogging by handwheel.
My problem is, if I jog in 1mm steps with my handwheel the whole floor is shaking because it seems that the machine is traveling in 1mm steps with maximum speed and acceleration. I want it to slow down when using the handwheel for a smooth motion when turning the handwheel a couple of steps..
whb.halui.max-velocity.value maybe that's the wrong pin for what I expect?
Best regards
Best regards
06 Jul 2021 10:26 #213864
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html
Have a look at the pins "axis.L.jog-accel-fraction"My problem is, if I jog in 1mm steps with my handwheel the whole floor is shaking because it seems that the machine is traveling in 1mm steps with maximum speed and acceleration. I want it to slow down when using the handwheel for a smooth motion when turning the handwheel a couple of steps..
- FedX
06 Jul 2021 17:05 #213908
by FedX
Thank you I'll give it a try when I'm at my workshop
- FedX
09 Jul 2021 10:53 #214119
by FedX
Thank you Andy ! It's working fine at 50% I would have never found this signal at axis..
Best regards
Best regards
- Yoshyluebeck
23 Feb 2024 08:16 #294076
by Yoshyluebeck
Replied by Yoshyluebeck on topic Probe Basic mx velocity for XHC- WHB04
Hello,
can you please show me where you used this command axis.L.jog-accel-fraction in the reverb? Which parameter did you use?
Greetings from Germany Lübeck
23 Feb 2024 15:41 #294123
Just add a line to your HAL file with something like
setp axis.x.jog-accel-fraction 0.5
It's not a command, it's a HAL parameter,Hello,
The following user(s) said Thank You: Lcvette, ChironFZ16, Muftijaja
- Yoshyluebeck
24 Feb 2024 00:23 #294181
by Yoshyluebeck
Hello andypugh,
This parameter was the solution to my problem. Thanks for the help!!! The machine now runs as smooth as butter in jog mode!
Moderators: KCJ, Lcvette
Time to create page: 0.132 seconds
