Where error is hiding?
- aleksamc
- Thank you received: 67
07 Aug 2021 02:02 #217100
by aleksamc
Where error is hiding? was created by aleksamc
I have maid some changes in my qtpyvcp GUI. When I try to load this GUI in linuxcnc it halts.
Where problem could be? Does it possible to see where to look from this Error messeges?
- Joco
- Thank you received: 327
07 Aug 2021 05:48 #217114
by Joco
Replied by Joco on topic Where error is hiding?
Have you removed the numberGroup? That's what is being complained about which suggests some attribute that used to be there and was being reference has either been removed or is now nested somewhere that it can not be referenced.
Cheers - j,
Cheers - j,
The following user(s) said Thank You: aleksamc
- aleksamc
15 Aug 2021 11:00 #217823
by aleksamc
Replied by aleksamc on topic Where error is hiding?
Yes, thanks I found this problem also.
There was such situation when I moved sub-screen to another place accidentally. When I saw it I moved it back, but possibly references lost.
I'm not so good (rather bad) in QtDeveloper, but is it possible to lock elements from moving if they are finished?
- Joco
31 Aug 2021 14:08 #219274
by Joco
Un fortunately not that I am aware of. Ctrl-z is you friend.
- aleksamc
01 Sep 2021 06:54 #219325
by aleksamc
GUI screen was bigger than that I used for editting, so I didn't see when I made such operation. It was too late when I see.
Moderators: KCJ, Lcvette
